98 ES300 Transmission Solenoid lite on-fix?
Old 06-08-08, 07:17 PM
jjmmd2003
jjmmd2003's Avatar
Default 98 ES300 Transmission Solenoid lite on-fix?
My 98 ES300 has 130k miles on it. Over the last year the engine warning lite came on & the Lexus folks say its the transmission solenoid. They flushed the tranny fluid as they said that that is usually the problem but the light came back on. So they said $1500 to reapir/replace the solenoid.
the light has been on for a year and 25k miles and I've noticed no problems?
Any cheaper options to repair it? any other mecahnics folks can reccommend on west side of Los angeles?
The car also needs some replacement of the front strut towers and control arms which is a $1400 repair and so I wonder if its worth doing.
Besides these two items and a small oil leak (main seal) car runs well & would like to see it last as long as many do.
I am a newbie & did search & would appreciate all the help.
Thanks
John
Santa Monica,CA
Old 06-08-08, 10:08 PM
tuan92129
tuan92129's Avatar
The solenoid might just be bad, or there are little metal pieces in the tranny which killed the solenoid -> tranny rebuild.
If they flushed the transmission fluid and didn't find metal, you can probably get away by replacing the solenoid.
Don't go to the stealership for service though.
Old 06-08-08, 10:17 PM
jjmmd2003
jjmmd2003's Avatar
Default do I
Do I even need to replace the solenoid or repair the tranny if the light has been on for 25k miles and no problem?
the lexus guys said that there are more than 1 solenoid in the tranny & they would recc replacing all of them. Thoughts?
any shop/mechanic reccommendatios in the west LA area?
Thanks
John
Old 06-11-08, 12:46 PM
jjmmd2003
jjmmd2003's Avatar
Default I am a newbie-first post
Please help me if you can please. Thanks!
Old 06-11-08, 04:47 PM
tuan92129
tuan92129's Avatar
Thanks
John
They should tell you the solenoid # that need to be replaced though. When my tranny was rebuilt, the first one was replaced.
Rickcl
05-13-16 08:29 PM
AlanHeat
15
05-19-14 11:56 AM
dum2lexus
Build Threads
01-10-14 04:22 PM
DSMCasey
05-10-10 08:32 PM
Max4Speed
Maintenance
02-10-03 09:25 AM
Quick Reply: 98 ES300 Transmission Solenoid lite on-fix?
