How hard...
Old 04-21-08, 10:15 PM
Vooduguru
Vooduguru's Avatar
Default How hard...
is is to change out the valve cover gaskets in the 93 es300?
Old 04-22-08, 07:48 PM
3000's Avatar
Maybe from 1 being easy to 6 being hardest, I give it a 3.5. But it requires patience and remembering where everything goes. If you never done it, I wouldn't suggest doing it yourself. The thing I hate is removing the intake plenum, the vacuum hoses and the egr bolts. It's just those tight little spaces that make it hard.
Old 10-24-08, 05:02 AM
fju2112
fju2112's Avatar
I just had 90K service done (timing belt, water pump, additional belts, etc. etc.) and they also found the spark plugs needed to be done along w/ the tranny fluid. They also recommended doing the plenum gasket but I brought most of my own parts and told them not to worry about it since I had forgotten to buy that part. So obviously this might be a couple hours in labor at a shop right? Is it just a maintenance item or is it something I really should have done at 90K? We're just over 90K now but we just put a lot of $$ into the car to do a bunch of stuff, so i guess another couple hundred couldn't hurt. What exactly is the "plenum gasket", I have not worked on the actual engine before and haven't heard this term used for other cars I've owned.
LS400UCF20
12-19-16 06:02 PM
BLKG3
08-07-12 10:43 AM
Lexis61509
12-20-10 08:08 PM
LexusPhan
08-21-09 05:45 PM
saelee39
01-16-06 08:53 AM
Quick Reply: How hard...
