Wheel spacers sizing
Old 01-06-08, 10:42 AM
palex
palex's Avatar
Default Wheel spacers sizing
Those of you that have wheels spacers, what method did you use to figure out what size was needed to fit flush. I have 17' wheels with a 45mm offset and 225/45/17 tires. I know I should probably run 215/50/17 none -the -less I put them on to see what they looked like and they were too sunken in and also rubbed on the strut tower. I have them posted for sale in the wheel forum. I am going to go with some 18" wheels instead and hopefully do a little more homework before my purchase. Any offset or spacer sizing will be gladly appreciated. I know many of you will also recommend a drop but that will have to wait until late summer or early fall.
Old 01-06-08, 10:59 AM
Sash
Sash's Avatar
I've got 15mm hubcentric spacers sitting in my rear due to having the same issue. I had a bunch of universal 5mm spacers that I used to see how much I really need for the wheels to sit flush.
Old 01-06-08, 11:04 AM
palex
palex's Avatar
Thanks Sash for the expedient response. Did you use spacers for the front also? What brand of spacers and how hard were they to install?
Old 01-06-08, 11:11 AM
Sash
Sash's Avatar
I didn't need spacers in the front because the wheel cleared the strut tower.
http://www.ichibausa.com/15alwhsp5.html
Those are the exact ones I've got. I had my shop pull out my old studs and put in longer studs. Wasn't hard at all . . the spacers go right on the studs.
Old 01-06-08, 04:04 PM
Choas
Choas's Avatar
You might be able to get away with 12mm depending on your width
SeanO
04-04-18 03:36 PM
Pearl250
05-06-10 07:45 PM
05ES330
Wheels, Tires & Brakes Forum
03-03-06 10:43 AM
djl
Suspension and Brakes
08-23-04 04:49 AM
gs4to4
13
08-01-01 03:53 AM
Quick Reply: Wheel spacers sizing
