Tranny slips on 98 ES
Old 09-20-06, 07:50 PM
lexuster1
lexuster1's Avatar
Default Tranny slips on 98 ES
Can any one help me on fixing the tranny slip problem?
I got a 98 ES with 102K miles on it. The tranny slips when it shifts between 1-2 and 2-3. The slippage can be observed more between 1-2 than 2-3. I checked the tranny fluid level and it is good. I am thinking of doing a Tranny flush with Dexron III (manual recommended).
Please help me if I need to check any other things to fix it....
Old 09-21-06, 12:45 AM
Pheonix
Pheonix's Avatar
Cool
Flush it. Stop driving it until then. Make sure you get it atleast filled back up to the hot fluid marks when you're done & you've shifted into all gear positions to purge the manual valve body of air.
Old 09-21-06, 07:52 AM
miltonlin
miltonlin's Avatar
Are you sure that it is Dexron III you have and not the Type-IV fluid? The manual may say one thing, and yet it is different in your car/dipstick. I would stick with the original fluid and not switch between the two. And please do not use any "universal" ATF.
Old 09-22-06, 01:31 PM
Pheonix
Pheonix's Avatar
Cool
TT-IV didn't come unto play util the 99's U140E transmission.
Dexron is specified for all the A54X family of transmissions (i.e. transverse v6 camry platforms '87-98).
Old 09-22-06, 01:32 PM
lexuster1
lexuster1's Avatar
Hey Milton,
I bought this car recently. How can i know which fluid was put in before? Or Is it a good idea to flush it and fill with DEXRON III fluid. Please let me know.
Thanks
Old 09-22-06, 02:43 PM
itgrowsind
itgrowsind's Avatar
Yes Flush it ASAP w/ dexron III
Old 09-22-06, 02:46 PM
itgrowsind
itgrowsind's Avatar
Fill it up with Dexron III
Old 09-24-06, 11:15 AM
lexuster1
lexuster1's Avatar
Came back from local pepboys just now. I did an oil change and tranny flush. I requested them to put Dexron III fluid and they replied that they use DEXRON III fluid for all.
If anyone wanna get any services at pepboys make sure you get the print outs of the coupons from pepboys.com. I used 25$ off coupon on 100$ or more. You can 50$$ off if it is 200$ or more. Also there are some mail in rebates if you search on their website...
Link to pepboys coupons...
http://www.pepboysemaillist.com/inde...nStartDownload
After the tranny flush and oil change....my car drives very smooth....and no slips at all.. Thanks every one!!
Now i need to get the shocks/struts get done some time later The rear struts are little harder when i go over speed bumps.....
Old 09-24-06, 12:31 PM
Tammy
Tammy's Avatar
You may wish to consider a drain and fill of the fluid every 15 thousand from this point.
Old 09-26-06, 10:44 AM
lexuster1
lexuster1's Avatar
Hello Guys,
I dont know what went wrong. Still i can feel some tranny slip.It is good for the first couple of days after tranny flush.
Please let me know what else i need to check. I checked the tranny fluid and its full and clean. Please shed some light for checking the other options.
Thanks and I appreciate your inputs...
Best
Lexuster..
Ltaboso
IS F (2008-2014)
64
02-24-23 11:14 AM
Rezaxxed
Performance
09-24-08 05:28 AM
LexFather
06-22-08 07:01 AM
Answer300
Performance
01-08-08 11:20 PM
Lexguy026
Maintenance
08-30-04 07:18 AM
Quick Reply: Tranny slips on 98 ES
