ES300 Engine Low RPM Dies
I have 98 Lexus ES300 with 77,000 miles. Here is my problem. The car starts and cranks fine and runs fine usually. But sometime right after I start the car and it is still in park the RPM gauge drops to the last line, but the engine is still running and you can feel a very slight vibration or rough noise, very hard to feel or hear. When you put it into gear say D the car doesn't roll forward until you press the gas. Usually with automatics the car rolls forward a bit even with out pressing the gas. If I step on the throttle a few times or just ingonore it and drive say for 30 seconds like leaving a parking lot. Then the idle goes back to normal around 1 or the line right below 1 and the car is fine. It so far has only happend right after I drive and try to restart the engine, like quick stops. It has never happend yet when the car has sat for a while right before starting it like in the morning.
Does anyone know what is causing this problem?
Thanks
Thanks
No. You need some kind of brush, and some kind of cleaner. WD-40, Deep Creep, TriFlow etc.
The best thing to do is take the entire manifold off & clean it. In which case you *normally* need 14, 12 & 10mm sockets, and an allen wrench.
Search for IAC valve on here. There should be directions on how to do it.
PalinkasJa
12-25-15 09:58 AM
PBLexusES
06-08-07 10:30 AM
