Out of Gas and Gas Door Won't Open...
Old 11-06-04, 07:59 AM
spxChrome
spxChrome's Avatar
Arrow Out of Gas and Gas Door Won't Open...
Hey Guys,
The other day the little hinge broke from inside the Gas Cap door. I went ahead and filled the car up with gas. But now I am out of gas and went to fill up again today but can not get the gas cap door open. The button inside the car and the little pulley in the trunck will not open the door. Anyone have any suggestions I been riding on a red light for a few miles and now I am stuck. I could pry it with a screwdriver?? But don't want to chip the paint. Any help would be greatly appriciated.
Old 11-06-04, 08:37 AM
steviej
steviej's Avatar
of course you need to replace the spring hinge, but you knew that.
Without the spinge hinge the door doesn't "pop" when you hit the button. The lock will release but the door doesn't move. To get it open you need to have something that will open the door while you hit the button or pull the handle in the trunk.
I have used in the past:
1. a q-tip. inset the q-tip in between the door and the body of the car. have someone hit the button while you use the soft end to apply pressure to the backside of the edge of gas fill door to get it open. The soft end will bind up behind the door and push it ajar just enough for you to get a finger on it.
2. Safe release masking tape. use it to stick to the door, hit the trunk button or pull the handle. Use the tape to open the door. The safe release tape will peel off very easily from the paint and not leave any residue nor will it harm the paint.
steviej
Old 11-06-04, 08:57 AM
spxChrome
spxChrome's Avatar
Thanks Steviej,
That worked like a champ.
Old 11-17-04, 09:39 PM
Romadoc
Romadoc's Avatar
Had the same problem today. The friendly Lexus dealer charged a total of $6.50 to change the broken spring.
Old 11-18-04, 12:33 AM
O. L. T.
Keeper of the light
Forum Moderator
O. L. T.'s Avatar
$6.50 is cheaper than a handshake there Most handshakes get you $50k in debt
Old 11-18-04, 02:10 AM
George Hsieh
George Hsieh's Avatar
are you for real????? cause the last time I went check they told me that I have to change the whole fuel door.. . it's not going to be $6.50 in my case...
George
Old 11-18-04, 03:22 AM
Romadoc
Romadoc's Avatar
According to my bill from Hennessy Lexus 5880 Peachtree Industrial Blvd.
part number: 77360-33020 spring assy, fuel
List. $6.07
Tax 0.43
Total: $6.50
There was also a bin location: A2A4
Old 02-02-06, 10:20 AM
slick20
slick20's Avatar
untill you able to get the door spring fixed,i have away to make this a one person operation.all you need is something to put under the relase lever to hold it up. you can than take yuor thumb and push on the left side of fuel door where hindge is door should come open.
Old 02-02-06, 01:07 PM
spxChrome
spxChrome's Avatar
Well it only took 1 year and 2 months but I got this fixed last week. Cost me $4 and they installed it for free.
Old 08-09-14, 08:00 PM
d1bartelt
d1bartelt's Avatar
Default binder clip
You can also use a small binder clip as a spring.
Watch this video on how to do it:
Old 08-10-14, 10:43 AM
Chuckinnj
Chuckinnj's Avatar
Grab one of those SMALL black spring clips with the foldable handles (used for paper clips) and clip it to the upper area of the fuel door with the handles open.......... Works great!
Old 08-10-14, 11:18 AM
crwys
crwys's Avatar
Lmao one year and two months.
Isn't there a lever you can pull in your trunk that opens the tank? My 1999 Lexus ES300 has one. Or would that not work if the button is broken? (I've never had to use it or know how it works, I just know it opens my gas tank)
Old 08-10-14, 11:44 AM
Hayk
Hayk's Avatar
The OP said that he tried that with no luck. The problem is not in the locking mechanism, but in the spring that pushes the door ajar.
Old 08-10-20, 12:21 PM
wkp
9th Gear
wkp's Avatar
I used superglue on the clip and held it in place with blue tape and let the glue dry overnight. All good.
Old 08-17-20, 11:09 AM
JohnOlson
JohnOlson's Avatar
Open the trunk. Check behind the fuel door inside the trunk. Pull the handle dangling from a cable specific to this issue, maybe behind the Furst Aid kit. Close trunk. Fuel.
Drive away.
Quick Reply: Out of Gas and Gas Door Won't Open...
