ES - 6th Gen (2013-2018) Discussion topics related to 2013+ ES models
Battery Drain Issue
Old 04-01-15, 10:27 AM
  #61
wrclapham
wrclapham's Avatar
My F-I-L is definitely a short distance driver. The typical drive ranges from 10 to 40 minutes round trip every few days (he is 84.) I doubt he ever gets above 40 mph.
Your suggestion is similar to the dealer in that they said just parking it in the driveway and running it for 20 minutes will not recharge the battery. If his type of driving in this model is not enough to keep the battery charged, I am at a loss. The good news is that he has not had any incidents in the last two weeks.
Old 04-01-15, 10:36 AM
  #62
wrclapham
wrclapham's Avatar
Originally Posted by sderman
It seems to me that if anything in the car is drawing down that much power then it must be warmer than it's surrounding. Might be worth leaving the car out overnight (or 2 nights) to allow all of it's components and surfaces to cool to ambient temperature. Then use an infrared thermometer to scan the various components and surfaces (the engine bay, interior, trunk) for warmth. It should point to the problem area. Apologies if this has been mentioned before.
Thanks, all suggestions are worth reviewing. Someone else suggested checking the car in the dark to see if any light was shining in under the hood, inside the car, or in the trunk. I checked for light (none) and also listened for any sounds while the car was idle in the garage, based on another finding that an evaporator motor (?) was running more than it should, but I did not hear anything.
I do have a handheld infrared scanner and could check for hot spots. I am hoping that since the car has not had any starting problems for about two weeks that maybe it is okay. My F-I-L will never leave the car for long periods such as an airport, his driving profile is fairly sedate.
Old 04-02-15, 08:43 AM
  #63
qlaval
qlaval's Avatar
Just back from a 30 days vacation, car started on first try. More the key FOB was about 20 feet from my car.
Old 10-06-15, 06:22 AM
  #64
01ESgray
01ESgray's Avatar
I am fighting the same problem with my 2001 ES. When I turn the key off the fuel pump stays on. It is difficult to hear unless in a quiet garage.
Old 10-09-15, 05:10 PM
  #65
delfini34
delfini34's Avatar
Have battery and alternator tested. Any of the national auto supply stores will do it for free. Next check for a "parasitic drain". This is likely the source if the battery checks out. YouTube can show you the method to do this.
Old 10-12-15, 10:17 PM
  #66
01ESgray
01ESgray's Avatar
Default result
I found that I had a bad relay. One of two that powers the fuel pump stayed energized after removing the key.
Old 10-13-15, 12:39 AM
  #67
Arty101
Arty101's Avatar
Removing key or powering down?
Old 10-13-15, 04:59 AM
  #68
Mike728
Mike728's Avatar
I think they still had a key in '01. He posted in the wrong forum.
dgallipeau
RX - 3rd Gen (2010-2015)
12
02-12-21 05:22 AM
relax221
04-06-16 10:03 AM
USCRugby
02-10-16 12:16 PM
bigblack06
04-29-13 08:15 AM
gloamin
01-07-13 10:08 AM
Quick Reply: Battery Drain Issue
