ES - 5th Gen (2007-2012) Discussion topics related to 2007+ ES350
Illuminated Door Sills for 07-09 Es350.
Old 03-28-13, 09:11 AM
SICK350
SICK350's Avatar
Default Illuminated Door Sills for 07-09 Es350.
I've recently have been looking into illuminated door sills for my 07 ES350 with no luck. I found a set for the 10-12 models on Aliexpress.com I added a link below:
http://www.aliexpress.com/item/free-...658120900.html
I asked the seller if they had a sill for the 07-09 model and he said its not available.
He said if there is enough of a demand for them he will make a mould and make some for the 07-09 model. What I'm looking for is about 20 plp that are interested in buying sills, maybe someone that can send me a 3D picture of a front and back sill to send to the manufacture.
Old 03-28-13, 09:19 AM
SICK350
SICK350's Avatar
Also if someone could post a picture of a 10-12 es350 front and rear door sills it would be greatly appreciated, I'm curious to see the difference.
Old 03-28-13, 10:53 AM
jcat_350
jcat_350's Avatar
I wouldn't think there is any difference at all to from 07/09 to 10/12 sills. They didn't change the whole body, just the lights and a few trim pieces.
Sounds to me like he's trying to bump his sales by catching you and 20 others in buying the same product.
Old 03-28-13, 05:14 PM
SICK350
SICK350's Avatar
I asked for dimensions first and those ones were almost double in width and both back and front were shorter, I was tempted to order these and try to fit them.
Old 03-28-13, 10:14 PM
jacobjohn
jacobjohn's Avatar
I would definitely be down to order one, if the price is right!
Old 03-29-13, 07:41 AM
jcat_350
jcat_350's Avatar
Don't forget factory ones have the metal part within the plastic. To me, those don't look much bigger than the whole assembly of metal and plastic on my 07.
Old 03-29-13, 07:16 PM
SICK350
SICK350's Avatar
All I measured was the stainless within the plastic and the dimensions he gave me were shorter than those, close to 1.5 inches shorter than the whole assembly.
I found a set for the lx models I'm waiting of him to get back to me with dimensions, these ones have the plastic around the edges and illuminate blue.
Old 03-30-13, 06:17 AM
SICK350
SICK350's Avatar
I thought I would post the dimensions of the kit above, after measuring there too wide.
The fronts are: 22" x 3 1/8"
The Back: 10" x 3 1/8"
But I found this kit of the lx and asked for the dimensions and they are:
http://www.aliexpress.com/item/illum...758374699.html
Front: 26" x 1 3/4"
Back: 16 3/4" x 2" to 2 3/4" (they taper).
Are factory dimensions are:
Front: 22" x 2 1/4"
Back: 13 1/2" x 2 1/4"
Check them out and let me know what you think.
Old 04-01-13, 07:29 AM
jcat_350
jcat_350's Avatar
the LX ones are 4" longer in the front and 3.25" longer in the back...those will not work.
The original set you posted is smaller but wider in the back and same but wider in the front. By the difference in dimensions it looks, to me, like they're supposed to replace the whole assembly, both metal AND the plastic tray that it sits in.
Old 04-01-13, 07:40 AM
SICK350
SICK350's Avatar
The door jam it sits on isn't even 3 1/8" wide they will over hang, I don't think them being a bit longer will make a big deal, I think it would be better than the shorter ones and not show and ware around the factory ones that might be there.
Old 04-01-13, 08:01 AM
SICK350
SICK350's Avatar
I do understand that they replace the whole assembly metal and plastic. The original set I posted are 3 1/8" wide and the jam it sits on is 2 3/4".
Old 04-01-13, 03:59 PM
wheinsky
wheinsky's Avatar
Looking at the OEM door sill part #'s, they are all the same for 07-12 ES350. Do they have any pictures of these installed on an ES350?
Here's a picture from edmunds of a 2011 and it doesn't look any wider than the one on my '08
oh and just picked up an '08 ES350
Old 04-02-13, 01:57 PM
SICK350
SICK350's Avatar
Thanks for the pic, no I have not seen a pic of these installed. I just noticed looking at the link is says rx350 in the link bar and es350 in the description.
Old 06-10-13, 11:20 AM
SICK350
SICK350's Avatar
I finally found the perfect replacement illuminated door sill for a 07 Lexus ES350, I got them in the mail today and installed them and they were a perfect match!
Old 06-10-13, 11:21 AM
SICK350
SICK350's Avatar
Here's a over all shot of a front one installed
Quick Reply: Illuminated Door Sills for 07-09 Es350.
