CLIMATE control [-simple Setting
if I get this correct,, the temperature u set , is what is called the Set point and the climate control tries to reach it..
if all I want is just outdoor air to be sent inside.- and if the outside air is -say for example 65. and my temp is set at 70, will this draw air from outsdie and try to heat it up a bit.
also- why does the A/C keep coming on. the screen lower left. that means the A/C is being consumed. which obviously I dont want.. even though it is set in heating mode.
If all you want is outside air, set the AUTO mode off, the A/C to off, your recirculation to outside or auto, and then set your temperature to LO. You'll get only vented air at whatever fan setting you've chosen. If your recirculation button is in the auto mode you might have to push it to select outside air. If you raise the temp then heat will match your setting, but no cooling below outside temperature will happen unless you push the A/C button on the climate control screen.
Interesting discussion here. I guess I must be to old but I would be happy if they got rid of the buttons and were always in auto mode. When I picked up the car I set it to auto and 70* and have never touched it. Works for me.
Jagtos: Unlikely you are older than I am (64), and I still experiment with lots of bizarre stuff. In fact, I just bought my first dirt bike--a KTM 450!
I haven't tried any "manual" settings on our ES either, but on our previous Hondas (all had "Auto" settings too), if I turned off the AC because it was cold outside, and set the recirculate mode to "Outside", we actually saw a slight increase in gas mileage on long trips. Not much, maybe 1-2 mpg, but it helped a bit to not run the AC compressor.
Not quite I've got 5 years on you. I am looking at getting back into Jags though and am deciding on whether I go for a roaster or a coupe. The Ferrari is a little raw so maybe an XKR will keep me happy in my old age. Oh as you can imagine 1-2 extra MPG's doesn't mean to much to me. Have fun with the bike . Enjoy the ride.
I don't like the car choosing to use A/C automatically or picking my fan speed, so I run the system w/o AUTO selected (the button on the far left of the climate control buttons). You also need to deselect the A/C on the climate control screen if it is on). The car will still attempt to maintain the temperature you select, but if it is lower than ambient all you will get is outside (or inside, depending on your recirculation setting) air without the A/C.
CORRECT.. . .this is the only way to do it.. ie. keep AC off and set the temp to LOW. it will by default. just grab outside air and push it in.. but the hiccup arises when the inside is set to 70 and the outside is 65. i would have to set the inside to lower than 65 and then it wont kick in the heater.. and just plain suck in air.. .
Same here. I leave it on auto at 68. At times I'll turn the temp value up or down a bit if I need a little more blast but usually not.
Yep I recall my fathers 49 DeSoto where the heater was optional. I wonder what year that heaters came as standard equipment. Our 53 Ford had one in it. For AC you turned the side vent window around . LOL
My first vehicle was a 4-cylinder 1932 Ford pickup. The heater was a small flap under the dash that allowed outside air, heated by the exhaust manifold, to enter the cabin. As a heater, it sucked. But, on warmer days, you could loosen the wing-nuts and fold the windshield out for "full-ventilation". LOTS of fresh air!
My first car was a 1968 Pontiac Tempest, with an inline 6 cylinder engine. There was so much room in the engine bay that it was very easy to work on the motor. My dad and I replaced the water pump, fuel pump, radiator, and all the hoses on that car. In addition, of course to tune-ups and oil changes. I really loved working on that car, but I loved even more my dad teaching me how to do it. That was when I was 16, about 100 years ago
