Transmission slip vs driving style....
I don't have the slip.
But I'm curious how you trans slip sufferers drive your cars, and if there's any correlation.
Do you drive like a granny, i.e 0 to 60 in 15 seconds?
or do you drive like a maniac, trying to beat everyone else's 0-60 record?
on the flip side, those without the slip, do you drive like a maniac too?
I suspect that a lot more people have tranny issues than reported, they just don't notice or it does not bother them enough. It is just like rattles, wind noise, etc.
The squeaky wheel gets the grease.
I've driven both my car and loaners both ways. I could get one of the loaners to flare with hard accelaration. The other loaner would flare no matter what. My car will randomly flare under either condition. No ryhme or reason.
It does not matter your driving style. Ons videos prove that, he did a granny version, aka baby flare, and he did a rapid accel version video and there is in between the two.
You bring up a good point. I think all cars have issues. However, not all people can detect an issue or even care, especially if they are leasing.
I think the biggest factor is the route you take whenever driving the car after it sets for 4 or 5 hours or more. I have never had a flare leaving my home and I have tried to do it. I go through a couple of blocks of residential roads and then to a 35mph speed limit road. It rarely flared leaving my workplace when taking my normal route home, traveling north on a 40mph speed limit road which is flat but with occasional stoplights. I do have to wait on a stoplight immediately out of our parking lot before heading out. It will flare regularly goiung south on the same road! Still flat but less stops and no waiting (usually) to head out. FWIW.
Pete
Pete
Pete is right in my experiences. If you have a stretch of residential speed stop and go before getting to a road where you can normally acellerate up to 45 pmh or more, you may miss this entirely, unless your car has a habit of slipping 2 to 3 as well as 3 to 4 as several report, the 2 to 3 you will catch even in residential speed stop and go.
So after reading all the threads, and comparing issues to your car, if you say you do not have issues, most likely you don't.
Also, there is a gray area with respect to trannys and how they shift where some folks might consider normal and others would not.
I can only speak for my car, but driving style seems to only effect the amount of rpm the flair has. If I'm light on the throttle it'll flair a couple hundred, if I squeeze the throttle a little more agressively, the rpm will jump more. It's a rarety when it doesn't flair under the standard conditions of first 3rd to 4th shift of the day, after sitting for 3 or 4 hours or after sustained highway driving (65 mph+) of an hour or so.
I concur with BillP. Mine slips 100% of the time when the car has sat for at least 3 or 4 hours. I can get up to ~1800 to 2000 RPM of slip if I'm on the throttle, and ~300RPM when driving less aggressively.
If you have the flare, you will know it. My car does not have the flare, but I did have a loaner car that did. Started the loaner car the same as I start my own, drove it down the same route to the main street, did everything consistant. The loaner flared more than once in the 36 hours I had it. My car has 9K miles and never has flared to date.
BeaksSC
Performance & Maintenance
02-26-15 08:33 PM
71715612
10-18-12 03:34 PM
gandro
ES - 5th Gen (2007-2012)
02-04-08 06:25 PM
