Replace seat heat light in center console Lexus ES300 1999
I'm trying to replace the bulb (I'm assuming it's a bulb) that lights up the heating button for the heat seats. There are two lights, one when the heat is on and a light when the heat is off (so you can see the button at night). I want to replace these lights but how do I remove the center console to do this? I can't find directions when I google it.
Pry up on the wood plate around the shifter with a soft blunt object such as a panel removal tool or screwdriver with tape on it.
You can then disconnect the wires and unclip the seat heater switches from the shifter plate.
The bulbs are on the sides of the switch - just twist it counter clock wise and it will come out.
Sepposam
01-26-19 03:44 PM
