Strut Tower Bar Pix
Old 03-03-03, 06:10 PM
Seattle ES300
Seattle ES300's Avatar
Default Strut Tower Bar Pix
Took about 10 minutes to install. I have only driven it around the neighborhood once. I do notice a slight difference in the steering response. Note, however, that this is my wife's car and my Acura is noticably stiffer and more responsive (I'm modded) than the Lexus so she may notice more of a change. No clearance issues at all. Good mod for ~$20 shipped.
Old 03-03-03, 06:12 PM
Seattle ES300
Pix:
Old 03-03-03, 06:54 PM
amrit50
amrit50's Avatar
it sure is, i got one this week also
Old 03-03-03, 07:25 PM
meZoom!
Super Moderator
meZoom!'s Avatar
that was basically my stb. gawd i MISS my 1mzfe!!!!!!!!!!! esp. seeing it in that color w/ the same bar!!!!! just about brings tears to my eyes....oh yeah, if you have it put on right, it will significantly reduce body rolls, most noticeably on slight uphill turns (i.e. freeway entrances). good luck!
edit: your thread just reminded me about mine...see thread.
Old 03-03-03, 07:44 PM
steviej
steviej's Avatar
when changing my oil yesturday, I realized that I no longer wanted to buy one.
I was leaning on it., I guess they come standard on the Gen3 ES now.
One less mod to worry about...kewl.
steviej
Old 03-03-03, 07:53 PM
squarehat
squarehat's Avatar
Yeah, I was almost certain the 2002 and up had them stock , so I was puzzled by why you wanted one, StevieJ. Is this the autobacs strut tower bar from eBay? If you other 1st Gen. owners are happy with them, I'll pick one up, too. Is anybody having clearance problems when shifting into reverse? That's my only concern after hearing MeZoom's story.
Old 03-03-03, 08:13 PM
meZoom!
Super Moderator
meZoom!'s Avatar
here's the scratch on the top part of the bar. it happened cuz i couldn't position it's height exactly right. Too low and it hits the plenum intake in some gears. too high and it scrapes the underside of the hood (actually, the black hood lining...you can see it's geometric pattern imprinted onto the bar if this was in person).
Old 03-03-03, 08:27 PM
meZoom!
Super Moderator
meZoom!'s Avatar
OH MY GOD
i just realized great news. my bar, while it initially looks exactly like SeattleES's, is different. it looks like His bar's angled portion, where it meets the mounts, is more sleek. mine was just plain fat and rounded the whole way through. If these are made by the same people, I suspect that they might have "fixed" the clearance problem....waiting to hear back from SeattleES.
Old 03-04-03, 07:45 AM
Invisibleman
Invisibleman's Avatar
Mezoom! I got the same bar as Seattle ES300. No clearance problems at all. How about you SeattleES300?
Old 03-04-03, 07:46 AM
Invisibleman
OH, and Which way is the correct way of installing it? I tried flipping it around and it made no difference...
Old 03-04-03, 09:03 AM
meZoom!
Super Moderator
meZoom!'s Avatar
it looks like the correct way of installing it would be just the way it's pictured in seattlees's post (the top left pic w/ the caption). meaning, the "bottom" of that pic would be facing the front. i don't think it fit quite right the other way for me.
answer this for me: is the bar portion circular all the way around?? or is it tapered "flattened" towards the ends??
Old 03-04-03, 01:40 PM
Seattle ES300
The bar is actually tapered throughout it's length. There do not seem to be any clearance issues. However, I do hear a squeak when going over bumps at lower speeds. I assume I may need to remove the bar and line the area with teflon/grease. Maybe it just needs to settle in...
Old 03-04-03, 04:28 PM
flipside909
Lexus Connoisseur
flipside909's Avatar
That could be the case or your strut mounts are probably worn.
Old 03-04-03, 09:15 PM
meZoom!
Super Moderator
meZoom!'s Avatar
agree. i had the squeak also in the front. not in the back cuz those were replaced. strut arthritis, so to speak.
Old 03-04-03, 10:52 PM
Seattle ES300
How do you fix the strut mounts then? It didn't squeak before I put the STB on the car.
Quick Reply: Strut Tower Bar Pix
