2000 Cluster Lights. Need help.
Ok, so yesterday I took out my cars instrument cluster so I could replace the original incandescent bulbs with leds. But it turns out you can only change the check engine light and brake light and all those other lights including the turn signals and the prnd2l. The only problem is I want to change the lights behind the fuel and the temperature and speedometer and what not. I have literally. I mean, literally searched high and low on how I go about doing this but literally nothing has come up. I see things about 92-96 lexus clusters but not 2000. Is it not possible to? I took it apart the most I could searching for those stupid lights and nothing. I just want to know if it's a lost cause. Thanks.
The backlight illumination is done via a fluorescent tube so there are no lamps you to swap with LEDs.
If you want LED we can do a custom setup for you.
__________________
TANIN AUTO ELECTRONIX
262-456-4147
contact@taninauto.com
www.taninautoelectronix.com
262-456-4147
This question was posted last month:
https://www.clublexus.com/forums/es3...001-es300.html
See my post for a link to writeup on disassembling the instrument cluster on the 97-01 ES.
I'm guessing the florescent tube isn't available as a separate part, but you'll have to buy a brand new cluster if you get it from the dealer.
Your best bet is the junkyard or a used cluster off eBay and grab the tube from those. See if you can find a low mileage one as they tend to yellow out the more they are used. Be careful when removing the tube - I broke one of mine when taking apart the cluster.
cubbieblu7
IS - 1st Gen (2001-2005)
06-19-12 04:41 PM
spinedoc
04-02-01 07:12 PM
