1995 Lexus es300 transmission problems
Old 04-02-14, 08:35 AM
Jolzer
Jolzer's Avatar
Default 1995 Lexus es300 transmission problems
I've had my 1995 Lexus es300 for about a year now and added 10,000 miles on it. It now has 120,000 miles. Recently checked my dipstick (while the car was running) and there are only two markings on it, hot and cold and my transmission fluid was way above hot. My bigger concern is that my transmission fluid is brown. Ever since i noticed this I have been paying close attention to how my transmission shifts. I don't want to call it rough but you can definitely feel each shift and when traveling at about 50 mph and take my foot off the accelerator it suddenly downshifts. I took it to my mechanic and he said not to change the fluid because the new thinner fluid will cause the clutches to slip even more and then he added a transmission fluid additive. Maybe that's why my level is so high. I know the transmission fluid was changed 60,000 miles ago and according to the owners manual it's time for it to be changed again. But if i leave the brown fluid in, how long will my transmission last and if i change it what are my chances of ruining the transmission?
Old 04-02-14, 01:30 PM
Received 2,712 Likes on 2,297 Posts
To be safe do a drain and fill and see how the transmission reacts, you will be replacing about 1/3rd of the fluid doing this. If you take your mechanics advice and just leave the old fluid in, the transmission will eventually fail for sure.
Old 04-02-14, 02:00 PM
Jolzer
Jolzer's Avatar
I know brown fluid usually means overheating, is that why the fluid on my dipstick is so high? and will the new fluid overheat as well?
Old 04-02-14, 02:45 PM
Fluid turns colour because of age/friction and also clutch material and metal particles contaminate the fluid. New fluid won't "overheat", make sure you get the level exactly right.
maurice01
11-24-19 02:48 PM
crwys
05-21-14 02:40 PM
99es300
09-21-09 02:09 PM
stvincent
Maintenance
05-12-09 05:04 PM
Bumbobee
02-26-09 04:21 PM
Quick Reply: 1995 Lexus es300 transmission problems
