Trac off, ABS and VSC lights are staying on ,How do you turn off
Old 07-16-13, 05:14 PM
dwb
dwb's Avatar
Default Trac off, ABS and VSC lights are staying on ,How do you turn off
Car was up and down off a lift several times , Now the Trac off , ABS and VSC lights are staying on and I can not figure out how to get them off. I diconected the battery , hit the button for the trac off nothing seens to work . I charged the battery back to new , no codes or lights other than these ones show on dash . Start car up lights are off , as soon as I move the car in reverse or foward they come on again / any help would be great .
Old 07-16-13, 09:02 PM
Received 3,048 Likes on 2,561 Posts
Bad ABS sensor or associated wiring would be my guess.
Old 07-16-13, 09:36 PM
mdbrown
mdbrown's Avatar
They are on for a reason. Pull the codes and find out why. Fix what is failing/failed then the lights won't be on anymore.
Old 07-17-13, 05:10 AM
brucelee1
brucelee1's Avatar
Usually this is a bad sensor.
Old 07-19-13, 12:48 PM
irisvercy
irisvercy's Avatar
You probably have re calibrate them. I believe their is a thread how to calibrate them
Old 07-19-13, 12:56 PM
irisvercy
irisvercy's Avatar
Zero Point Calibration of Yaw Rate and Deceleration Sensors Using SST 09843–18040.
When having replaced the yaw rate sensor, deceleration sensor or the ECU, perform the process for zero point of yaw rate and deceleration sensors as shown below.
1. Ensure the shift lever is in “P” range.
2. Turn the ignition switch ON.
3. Using SST 09843–18040, repeat a cycle of short and open between terminals Ts and CG of DLC3 4 times or more within 8 seconds. Verify that the VSC indicator light is lit indicating the recorded zero point is erased.
4. Turn the ignition switch OFF.
5. Be sure the terminals Ts and CG of DLC3 are disconnected.
6. Turn the ignition switch ON.
7. Check that the VSC warning light goes off about 15 seconds after the ignition switch is turned ON.
8. After ensuring that the VSC warning light remains OFF for 2 seconds, turn the ignition switch OFF.
9. Connect the terminal Ts and CG of DLC3 using SST 09843–18040.
10. Turn the ignition switch ON.
11. After turning the ignition switch ON, check that the VSC warning light
is lit for about 4 seconds and then starts quick blinking at
0.13 second intervals.
NOTE:
While performing the zero point procedure, do not tilt, move or shake the vehicle. The vehicle must remain in a stationary condition throughout the entire process. Do not start the engine and be sure to perform the procedure on a level surface with an inclination of less than 1%.
Ts
CG
Old 07-22-13, 06:15 AM
dwb
dwb's Avatar
Thanks !!!! that was the problem , Had to be recalulated. All is fine now .
vwynn
09-27-22 02:43 PM
mandyfig
06-20-22 04:29 PM
anon1m0us
GX - 1st Gen (2003-2009)
09-15-13 07:01 PM
1NICESC430
08-31-10 01:37 PM
Cannonbear
Maintenance
08-15-05 07:46 PM
Quick Reply: Trac off, ABS and VSC lights are staying on ,How do you turn off
