Lexus ES330 Push Button Start?
Has anyone installed push button start for there lexus es330? It looks sweet.
http://www.advancedkeys.com/Prod_AK103B.html
How does this get past the steering column lock?
I can only imagine the wiring behind all this, unless it links with the car's CANBUS to control everything.
Did you have to give up one key to bypass the immobilizer?
I was thinking the same thing. It looks pretty clean. But I can only imagine he had to give up a key to bypass the factory immobilizer. There isn't really a way around that.
Easyguard Universal Top Quality PKE Car Alarm System Passive Keyless Entry Auto Start Push Button Start with Password Keypad https://www.amazon.com/dp/B011HOJRME..._mj6Uwb00KZ7P9
As far as installation I took it to an installer he charged me $400 bucks. I did lose a key because it had to be cut into the ingnition to bypass the steering wheel lock.
The ignition has an engine immobilizer that communicates with a small chip in your key to start the car. You give up the key because the installer uses it as a bypass to the factory immobilizer system to start the car with the button instead of with your key.
