Installing a remote car starter?
Old 10-11-09, 11:53 AM
mdpuff
mdpuff's Avatar
Default Installing a remote car starter?
Hey out there, does anybody know what it takes to install a remote starter in a 01 ES300? We are parking our SC430's for the winter and are looking at an ES300 for a winter beater and my wife wants a remote starter. Is there any threads in other forums that relate to this that anybody knows of? Any help would be greatly appreciated!!
Old 10-11-09, 05:07 PM
DixonPai
DixonPai's Avatar
there was a kit on sell , but i don't remember what the site was, sorry, but if you do, do it, i want see how it goes, just google/ebay push start kit, I am shure you can find something. Good Luck
Old 10-30-09, 08:56 PM
kidd1
kidd1's Avatar
here is the wiring for it hope that helps. u will also need a bypass mod to bypass the anti theft during remote start sequence
2001 Lexus ES 300
Remote Start, Security, Keyless Entry, Accessories
Item Wire Color Polarity Wire Location
12 Volts white - white/red + ignition harness
Second 12 Volts
Starter red + ignition harness
Second Starter
Ignition black/yellow + ignition harness
Second Ignition black/red + ignition harness
Third Ignition
Accessory blue/red + ignition harness
Second Accessory
Third Accessory
Keysense blue/black - ignition harness
Data Bus grn/wht (data), red/blu (clock), blu/yel (synchro) data Immobilizer Module
Can Bus High
Can Bus Low
Can Bus Sw
Power Lock dk. blue/white - theft module
Power Unlock dk. blue - theft module
Lock Motor blue/red org plug bottom of fusebox
Driver Unlock Motor blue org plug bottom of fusebox
Passenger Unlock Motor blue/black org plug bottom of fusebox
Parking Lights (-) green steering column
Parking Lights (+) grn/org or grn/blk bottom of fusebox
Hazards
Turn Signal (Left)
Turn Signal (Right)
Headlight red/yellow - steering column
AutoLights
Reverse Light
Left Front Door Trigger red/white - top of fuse box
Right Front Door Trigger
Left Rear Door Trigger
Right Rear Door Trigger
Remote Start, Security, Keyless Entry, Accessories (Continued)
Dome Supervision
Trunk/Hatch Pin red/yellow - trunk light or theft module
Rear Glass Pin
Hood Pin black - pin switch or theft module
Trunk/Hatch Release red - release switch
Trunk Release Motor
Fuel Door Release
Power Sliding Door (Left)
Power Sliding Door (Right)
Factory Alarm Arm arms with lock
Factory Alarm Disarm disarms with unlock
Disarm No Unlock use key sense wire
Trunk Alarm Shunt
Tachometer gray
Wait to Start
Neutral Safety
Clutch Pedal
Fuel Pump
Rear Defroster
Mirror Defroster
Left Front Heated Seat
Right Front Heated Seat
Speed Sense purple/white cruise control module
Brake Wire green/white + bottom of fusebox
Parking Brake
Horn Trigger green/black - steering column
Wipers blu/blk(L),blu/org(H + steering column
Left Front Window (Up/Down) green - red A drivers door switch
Right Front Window (Up/Down) grn/wht - red/blu A drivers kick panel
Left Rear Window (Up/Down) grn/yel - red/yel A drivers kick panel
Right Rear Window (Up/Down) grn/blk - red/blk A drivers kick panel
Sun Roof (Open/Close)
Sun Roof (Limit/Close)
Memory Seat 1
Memory Seat 2
Memory Seat 3
Mero121
10-16-11 01:19 PM
geosommer
Hybrid Technology
13
12-21-07 08:29 AM
Tranman
10-03-05 03:26 PM
phoaddict
IS - 1st Gen (2001-2005)
06-07-02 10:04 PM
Quick Reply: Installing a remote car starter?
