Is it hard to change a power steering pump es 300
Old 10-29-08, 01:46 PM
goldlexus9
goldlexus9's Avatar
Cool Is it hard to change a power steering pump es 300
How hard is it to change a power steering pump on a 1994 lexus es 300?can some 1 help???
Old 10-29-08, 02:03 PM
JSM1284
JSM1284's Avatar
It's Easy:
Refer to Fig. 30 when replacing power steering pump, noting the following:
Disconnect and connect the pressure line using power steering hose nut wrench set 09631-22020 or equivalent.
Bleed power steering system after installation.
Old 10-29-08, 03:49 PM
goldlexus9
goldlexus9's Avatar
Thanks for getting back to me,as far as bleeding the system is that on the rack??
Old 10-29-08, 04:11 PM
JSM1284
JSM1284's Avatar
Ensure fluid in reservoir tank is at proper level.
With engine speed below 1000 RPM, turn steering wheel from stop to stop three or four times, keeping at full stop position for two to three seconds.
Ensure fluid is not foamy or cloudy.
Measure fluid lever with engine running then stop engine and measure fluid level again, Fig. 1. Maximum rise of of fluid is .20 inch.
If a problem is found, proceed as follows:
Disconnect return hose from reservoir tank and drain fluid.
Fill reservoir tank with fresh fluid.
With return hose placed into a suitable container, start engine and run at 1000 RPM. After 1 or 2 seconds, fluid will begin to discharge from the return hose. Stop engine immediately at this time. Ensure that some fluid remains in the reservoir tank.
Repeat steps b and c four or five times until there is no more air in fluid.
Connect return hose and correct fluid level.
Old 10-29-08, 08:53 PM
llcoolpass
llcoolpass's Avatar
He's not kidding, this car is much easier to work on than other cars
dashan
11-12-14 08:04 PM
Dx3
Suspension and Brakes
32
04-07-13 07:36 AM
shajbot
Maintenance
10-21-08 04:06 PM
OldSkoolGS
GS - 1st Gen (1993-1997)
14
03-11-04 10:28 AM
Neal Rikal
SC- 1st Gen (1992-2000)
11-21-02 07:15 PM
Quick Reply: Is it hard to change a power steering pump es 300
