1995 Es300 Starter Relay
Old 08-20-07, 12:19 PM
rhwest2008
rhwest2008's Avatar
Default 1995 Es300 Starter Relay
I HAVE A 95 ES300 AND THERE IS NO POWER GOING TO THE STARTER. I CANT FIND THE RELAY FOR THE STARTER.
Old 08-20-07, 08:50 PM
CUMan
CUMan's Avatar
There are two small boxes containing numerous relays close to the right side of the battery (looking at the engine from the front). The starter relay is in the front box. It is near the front of the box.
This particular relay is blue in color. The part number is 28300-10020. It is probably used in Toyota models as well as Lexus models. You can probably get it cheaper at a Toyota dealer.
Don't just pull up on the relay to remove it. There is a small clip near the bottom on the right side which has to be released by inserting a screwdriver between the relay body and the clip.
Old 07-04-14, 10:08 AM
jdmben710
jdmben710's Avatar
dont pull the blue its a purple colored relay and to make sure its not the relay jump terminals 1 and 3 if the motor starts you have a relay prob.
danielmccl
06-18-18 11:56 PM
Nonnname
13
12-04-16 07:16 AM
mcbalagtas
12-06-12 02:36 AM
Strida
07-17-05 05:23 AM
branshew
08-26-04 05:20 PM
Quick Reply: 1995 Es300 Starter Relay
