aftermarket radio+stock antenna
Old 04-28-07, 03:10 PM
LovEnPeaCe
LovEnPeaCe's Avatar
Default aftermarket radio+stock antenna
you might have seen my other post, but i thought i might get some better responses here. i have a '94 es300 with an aftermarket radio and i'd like to know how to replace the antenna mast and also hook up the radio so that the antenna goes up&down with the radio. any help?
thanks a lot!
Old 04-28-07, 08:14 PM
Choas
Choas's Avatar
thanks a lot!
If you can post a wiring diagram of the aftermarket head unit or just give us the model and we will find it for you. Also if you already know a little about stereos all you need to do is hook up the remote wire to the antenna wire for the stock setup and the wiring diagram has been posted here countless times just use the search tool.
Old 04-30-07, 09:24 AM
GrahamHill
GrahamHill's Avatar
Mine continually went up and woulddnt stop. I unhooked the harness while it was up so it just stays there all the time. The only way I could make mine work was with a momentary button to raise it (and it goes down when the key turns off).
Any idears??
Old 04-30-07, 06:18 PM
LovEnPeaCe
LovEnPeaCe's Avatar
the hu is an eclipse cd3000. i connected the light green+red stripe wire to the blue wire on the cd3000 which is labeled for antenna relay and the motor for the antenna doesn't go up/down when i do. i tried turning the radio on/off and changing from disc to fm, but still no luck
Old 04-30-07, 07:55 PM
Choas
Choas's Avatar
try tapping a power wire to the wire for the antenna realay and see what it does.
Old 04-30-07, 09:31 PM
GrahamHill
GrahamHill's Avatar
It goes up when the wire is energized. When it gets to the top the gears just grind until you stop powering the wire. It goes down when you turn the ignition off.
Old 05-01-07, 06:12 AM
Choas
Choas's Avatar
Yea the switch you have is prob the only way to fix it. It prob is becase the stock hu only energizes the wire when it wants it to go up and uses a separate signal to make it go down. What I would do is acess the motor for the antenna and test how you can make it go down.
Old 05-01-07, 04:08 PM
GrahamHill
GrahamHill's Avatar
I'll just leave it up for now, lol. A timed relay would solve the deal though.
Old 05-01-07, 08:03 PM
Choas
Choas's Avatar
Don't go through a car wash then.
Oldsports
10-05-18 05:18 AM
caverman
08-03-17 05:40 AM
Daniel N
07-09-09 01:47 PM
hd54321
12-07-04 07:40 PM
sc300jon
04-23-01 11:10 AM
Quick Reply: aftermarket radio+stock antenna
