es300 95 gauge cluster led needles
Old 03-22-07, 01:06 PM
vstolyarov
vstolyarov's Avatar
Default es300 95 gauge cluster led needles
will the 97 fit or higher years, or can i buy cluster and replace just needles?
i found out that some site said es300 92-93 is yellow led, while 94-96 is red is that true?
how common is it for the leds to burn out?
b/c if i am getting a used cluster i might have same problems again.
Old 03-22-07, 01:33 PM
cino135
cino135's Avatar
https://www.clublexus.com/forums/sho...threadid=83360
this should help
Old 03-22-07, 02:01 PM
vstolyarov
vstolyarov's Avatar
do 97 up needles burn out?
wikipedia says it uses new electroluminescent Optitron instrument panel? what does it mean?
Old 03-22-07, 02:27 PM
Lexucan
Lexucanafer
Lexucan's Avatar
I don't think the '97 ES needles will burn out. It's the 2nd generation (1992-1996) that have this common problem. But I don't know if the '97 needles are compatible with your '95 cluster. There's a link to a DIY for fixing the needles in my sig, if you are interested.
Old 03-23-07, 04:38 PM
tuan92129
tuan92129's Avatar
You can send the needles to lextech.org
RxG300
SC- 1st Gen (1992-2000)
08-24-13 01:11 PM
xiaolong
05-17-13 02:59 PM
S142jz
06-01-10 07:47 PM
ucfa4
SC400 / 300 Classifieds
04-25-08 03:25 PM
Quick Reply: es300 95 gauge cluster led needles
