Idle in Reverse
Idle in Reverse
Ok so my car has an idle problem i think. When i turn on the car it gets pretty high but not passing 2000 rpms but even when i put it into drive and reverse does it climb again any one had this problem before?
i think it's prefectly normal for the needle to JUMP near 2000RPM when you First start your car.. it should climb a little down to 800RPM after it's all warm up.. and when you shift it's perfectly normal for the RPM to jump..
grindin8o8
Performance & Maintenance
03-08-10 06:25 PM
