Club Lexus Vendor Marketplace The place to find group buys and great deals from ClubLexus' supporting vendors.
Replacement Car Keys - Cutting and Duplication Services
Old 07-27-15, 12:08 PM
iKeyless
Former Sponsor
iKeyless's Avatar
Lightbulb Replacement Car Keys - Cutting and Duplication Services
Car keys cut and duplicated by iKeyless
iKeyless LLC is the world's largest supplier of replacement keys, but our services don't stop there.
We also provide key cutting services, replacement shells, and new remotes as well!
Is your key damaged or unusable? Looking for a spare? Why spend $300 or more on a new one from the dealership when you can get one from us for 75% less???
We use the same high quality materials the manufacturers use in our keys, so no worrying about a cheap, aftermarket key you will have to replace shortly after receiving it. We have the fastest turnaround in the industry and can often mail your custom cut-to-code key out to you the same day you place an order.
We can send anything from an uncut empty key shell up to a fully functioning fob that is cut for your exact vehicle and programmable as well. So if you're in need of a whole new key or simply want a quick fix to the common breaking of Lexus keys, we have you covered!
To order, simply call Scott or Jeff at 502-528-8177 or email us at ScottS@ikeyless.com or JeffF@ikeyless.com and we will provide you with solutions to your key needs.
We also have many more makes, models, and brands we service so if you have another car in the family that needs a new key or replacement part let us know! We have the largest inventory of replacement pieces in the industry and will gladly help you get what you need- fast!
ASK ABOUT COLORED SHELLS!
From Acura to Volkswagen, iKeyless is your one stop shop for replacement key parts.
- Scott & Jeff
Old 08-03-15, 08:10 AM
iKeyless
Former Sponsor
iKeyless's Avatar
Default Tons of Lexus Keys and Shell
Contact Scott or Jeff for Lexus keys and shells. 502-528-8177 or info@freshcarkeys.com / jeffF@ikeyless.com
Old 08-06-15, 12:04 PM
iKeyless
Former Sponsor
iKeyless's Avatar
Default "we've had a lot of messages regarding used Lexus keys, here's the scoop".
If the malfunctioning key is either brand new / never before programmed OR has previously been programmed to your car, a dealer or locksmith with the appropriate tools can reprogram it to the vehicle with really no problems. It's rare for a key to simply lose programming. If it appears in perfect physical condition, perhaps it is new and never programmed to the car?
If it is a used key that has not previously been programmed to your car, you may be able to use it. As J3ff mentioned, you must first check to ensure the FCC ID's on the back of the keys are the same. If the FCC ID ends with AAB, there are two of these keys that look identical and they are NOT interchangeable. One is for earlier, roughly 2005-2006 Lexus and the other is for roughly 2007-newer. I can't recall which one is which. It's in the top corner of the PCB inside the key, near the LED. One part number is 0140 and the other is 3370. If your unprogrammed key matches the one that works, you can have it programmed.
As far as programming goes, I would strongly recommend you contact a locksmith in your area that program used Lexus keys. That is a guaranteed way to get it working. They have to reset the immobilizer on your vehicle to program a used key to it, so you definitely want to ensure they have the ability to program used Lexus keys because not all locksmith / key programming equipment can reset the immobilizer, which is the only way to add used keys to it.
You could also ask a dealer but I'm honestly not sure if they can program used keys.
My recommendation for you would be to ensure the keys match and just have it reprogrammed by a locksmith with the credentials listed above. It will be less expensive if they have a showroom you can drive to rather than them come to you. This is a quick, surefire, (comparatively) inexpensive way to get the key working on your car again.
Old 08-10-15, 06:33 AM
iKeyless
Former Sponsor
iKeyless's Avatar
Default We have all makes and model remotes...not just Lexus
We have replacement key blades, shells, and emergency insert blades! We have BMW, Audi, Land Rover, Chrysler, Ford, Chevy...you name it we have it! Email me at JeffF@ikeyless.com
Old 08-12-15, 07:11 AM
iKeyless
Former Sponsor
iKeyless's Avatar
Default Hump day Bump day!
5% off all shells and inserts for Club Lexus Members! Just email jeffF@ikeyless.com
Old 08-19-15, 09:16 AM
iKeyless
Former Sponsor
iKeyless's Avatar
Default Do you only have one working key?
Contact us today for a replacement or spare remote, we can also cut key blades!
Old 08-26-15, 09:05 AM
iKeyless
Former Sponsor
iKeyless's Avatar
If you don't have a spare key/remote and you lose your original get ready to shell out some serious cash! Let us save you money now, instead of getting ripped off from the dealership later!
Contact Scott or Jeff at 855-373-7453 or 502-528-8177 or email at jeffF@ikeyless.com
babbles
ES - 6th Gen (2013-2018)
09-05-18 03:25 PM
iKeyless
09-30-15 07:35 AM
Jeffm15
11-14-10 05:20 AM
Ex996
10-10-05 03:02 PM
Quick Reply: Replacement Car Keys - Cutting and Duplication Services
