For FASTER Service and Quotes, You can now Text Message Mod in Japan!
Text Message us here: 657-229-0050
JIC MAGIC USA
TRUE COILOVERS FOR RC F and GS F
PRICE $2780 without helper springs
add $100 with helper springs
RC F AND GSF full coilover kit come with front and rear extra thick aluminum upper mount for safety reason. both upper mount will come with hard rubber mount. lower bracket are full CNC machines aluminum. lower bushing are using spherical bearings for long life time use. after market rubber is not enough to use long team. all shock are full aluminum and cylinder ID is 48mm. using 48MM OD full CNC machined special pistons for make better performance and ride. The fluid we are using is 100% synthetic made in USA.
Front spring we use for GSF & RCF is 16kg + Helper spring (better daily ) rear is 8kg-225mm springs.
front dual springs. rear is single spring set up. dampening is 32 step.
