CL Vendor Products for IS-F New product details, group buys and more, specifically for the IS-F model from CL Vendors
Gathering Interest FIGS Fabricated Side-Duct Oil Cooler
Old 08-22-16, 03:38 PM
FIGS
The Maker
FIGS's Avatar
Default FIGS Fabricated Side-Duct Oil Cooler
Hello all, since we have completed initial testing with our oil cooler setup I thought I would see might be interested in the system.
Currently the setup includes:
-10 row cooler mounted in the passenger side front bumper area.
-Fabricated ram air ducting via the front fog light. Brake duct could be re-purposed as well but the fabrication and cast would increase.
-Fabricated shroud to seal in front face of cooler to increase efficiency.
-Thermostatic sandwich plate adapter currently at 180 degrees.
-10AN lines and black anodized fittings.
-Initial results show a 20 degree F drop in oil temps and 5 degree drop in coolant and rapid thermal recovery from elevated temp events. Tested during the Central City Pit Rally Hill Climb event.
Currently we are looking at small run pricing around $750-1050 depending on cooler options and ducting.
-All fittings and mounting plates included and upgradable to larger cores or even custom cores if interested.
Old 08-24-16, 07:18 AM
stick
stick's Avatar
More pics please!
Old 08-25-16, 03:00 PM
FIGS
The Maker
FIGS's Avatar
All lines run coupled through the side access to the engine bay, no trimming of shrouds or covers.
__________________
Redefining Lexus Aftermarket Parts Since 2001
-- We are your Lexus suspension experts--
BCR - KW - PENSKE - OHLINS - HKS - GREDDY - STANCEPARTS
Links - Arms - SuperPro Poly Bushings - Solid Bearing Conversions - Motor Mounts
RB BBK's and 2P Rotors, G-Loc pads, Radium Fuel Systems
Custom Fabrication Design and Machining - Industrial 3D Printing - Laser Cutting
2018 USTCC Sportsman Class Champions - 2018 NASA ST5 National Champions
Old 10-02-20, 07:24 AM
FIGS
The Maker
FIGS's Avatar
An alternate version is also finally in the works. Testing will start to see how it does but happy with the sheetmetal fitment and the fact that there is a rubber plug in the lower liner that can be removed easily. An underscoop will draw air through the hole and pressurize the duct. 2 Spal pressure flaps allow side air in during low or negative pressure situations.
__________________
WhyHateTho (11-14-20)
Old 10-05-20, 07:21 PM
sunman6
sunman6's Avatar
very interested in this and looking forward to the results compared to the original version.
Old 03-22-21, 08:14 PM
funshine
funshine's Avatar
I may have missed this in the thread - Where does the thermostatic sandwich plate get mounted?
Old 03-24-21, 10:07 PM
FIGS
The Maker
FIGS's Avatar
It is mounted on the opposite side of the oil filter. In between the oil pickup manifold and the factory oil-water heat exchanger.
Thanks, Mike
__________________
Fysisist
RC F (2015-present)
16
01-11-16 06:07 PM
Ltaboso
IS F (2008-2014)
07-27-15 04:08 PM
Sonic_RC
Performance
05-30-14 01:51 AM
lexus-is2
04-14-14 01:05 PM
Doco21
06-02-09 06:50 PM
Quick Reply: Gathering Interest FIGS Fabricated Side-Duct Oil Cooler
