Mazda 3 issues. DTC 442
so my wives 2006 mazda 3 has issues starting, but only when after she puts fuel in the car. the car turns over put she has to step on the accelerator for it to start completely. any other time is fine. the STC code P0442 is an evap. any suggestion?
What is your usual engine temperature when this start-problem occurs....hot, cold, lukewarm, or in all temperature ranges? (warm or hot being defined as at or above 140 degrees, which is usually the lower-end of the normal-range on the temperature gauge or at the point where the blue cold-temperature light goes out).
try this link.....its for a Mazda 6 but may be relevant...
http://repairpal.com/every-time-i-re...wont-start-154
see answer 3.....
or....
http://www.justanswer.com/mazda/48en...ting-fill.html
there's a TSB listed in there.
see answer 3.....
after a year of living with this same issue, found a link that pointed me to the "charcoal canister purge solenoid" took 5 minutes to replace, problem fixed!
or....
Superfast1
03-23-18 07:17 AM
m1k3yg
GS - 1st Gen (1993-1997)
09-16-12 11:19 PM
Rock-a-Lex
Performance
03-20-07 12:59 PM
