1jz vvti compression
Old 12-21-13, 01:53 AM
optionjz
optionjz's Avatar
Default 1jz vvti compression
so, my car is burning oil and it's driving me crazy.. it came down to the valve seals or the piston rings..
The car puffs oil out after the end of revs, and on decel, even the slightest blip of the throttle would puff out a little smoke. Its defiantly oil.
anyways i did a compression check tonight and came across 120psi on all cylinders.. i thought it was rather low, and though maybe the compression tester just reads low.. BUT i did add oil to one of the cylinders to see if it would make a difference. I repeated the test on the cylinder i added oil into and the tester read much higher, like 180psi.
i didn't continue on the rest of the pistons because of anger, but by doing this test, are my rings fried?
all the cylinders are consistent at 120psi.
at 1:30 you can see the smoke on decel, while its on the dyno.
P.S- for some reason video isn't working go to-http://www.youtube.com/watch?v=z1BqUlsjXww&feature=c4-overview&list=UUCtLzg1wRhZXtWyZVQfc2hQ
the car did 310whp with stock turbo at 15psi.. which confuses me if the rings are so shot, IF SHOT..?
optionjz is offline
driftsc3
Performance & Maintenance
09-25-14 12:21 PM
Golden95SC
12-09-13 07:30 PM
estomax
09-11-13 05:12 AM
ucfa4
01-01-08 06:01 AM
Quick Reply: 1jz vvti compression
