Next-generation Mazda Miata could be lightest version ever , 1,800 LBS
Old 06-08-11, 08:31 PM
LexFather
Guest
Posts: n/a
Post Next-generation Mazda Miata could be lightest version ever , 1,800 LBS
Very ambitious target!
Targeted curb weight of 1,760 lbs (798 kg)
The Mazda Miata has always been a lightweight car, but a new report is indicating the next-generation model could weigh less than 2,000 lbs (907 kg).
Citing a "senior insider," Inside Line says that engineers have been tasked with cutting at least 720 lbs (327 kg) from the current curb weight of 2,480 lbs (1,125) kg. This means the car would tip the scales at just 1,760 lbs (798 kg).
In order to achieve this, the Miata will reportedly feature a high-strength steel body, a smaller engine and a minimalist interior. Speaking of the latter, the model could lose the glovebox and owner's manual - which would be replaced by a digital version on a USB flash drive - to save weight.
While this all sounds rather exciting, the source doesn't believe Mazda will actually meet their target weight. Regardless, the next-generation Miata should be significantly lighter than the current model.
Source: Inside Line
Read more: http://www.worldcarfans.com/11106083...#ixzz1OkJtiX5S
Old 06-08-11, 08:38 PM
KillaIS250
KillaIS250's Avatar
I knew this was coming some day
KillaIS250 is offline
Old 06-08-11, 09:24 PM
JessePS
JessePS's Avatar
Nice!!!! They could even drop in a nice rotary engine in this puppy. So it be a small and powerful engine 1.3L with over 200 hp. If you add two turbos, it turn out over 250 hp. The weight, the engine and it being FWD. It probably could do 0-60 mph in 5 seconds or less.
Come on Mazda do it!
Plus with that kind of engine and weight... It could be in Lotus Elise territory and if you add a turbo it be in Lotus Exige territory.
JessePS is offline
Old 06-08-11, 09:26 PM
gengar
gengar's Avatar
Love the direction.
gengar is offline
Old 06-08-11, 09:30 PM
TwiBlueG35
TwiBlueG35's Avatar
Great news if it could actually happen. But don't give us a 1700lb MX-5 with merely 105hp haha.
TwiBlueG35 is offline
MR_F1
MR_F1's Avatar
Impossible. An Elise is about 1870lbs. Can't see the Miata bettering that and still being road legal and reasonably priced.
MR_F1 is offline
Old 06-08-11, 09:48 PM
gengar
gengar's Avatar
The original Elise only had 120hp. It doesn't take a lot of hp to move 1700lbs and that isn't the focus anyway. I think it's a good way to differentiate from the rest of the market and cater to enthusiasts, given the movement of other manufacturers to pure hp wars while ignoring low weight, handling, and the fun-to-drive factor.
Use of a smaller engine as stated could bring down the weight substantially. Keep in mind the last-gen Miata actually used a bigger engine than the current Elise.
gengar is offline
Old 06-08-11, 10:54 PM
Hoovey689
Forum Moderator
Hoovey689's Avatar
I like the idea, but toss this into the rumormill and I'll believe it when I see it
Hoovey689 is offline
Old 06-08-11, 11:18 PM
jadu
live.love.laugh.lexus
Forum Moderator
jadu's Avatar
go mazda! way to cut down the weight
jadu is offline
Old 06-08-11, 11:24 PM
Squirrelz
Squirrelz's Avatar
Like where this is going. Doubt it will happen. I say ~2200lbs if anything.
EDIT: this still makes me wonder how that one raptor car got a V8 and still weighs under 2200lbs.
Squirrelz is offline
Old 06-09-11, 04:02 AM
IS350jet
IS350jet's Avatar
I'm sure it was just a typo but Miatas are RWD.
IS350jet is offline
Old 06-09-11, 04:41 AM
caddyowner
caddyowner's Avatar
I hope Mazda has realized that the Wankel engine should be in the dustbin of past automotive powertrains.
caddyowner is offline
Old 06-09-11, 04:47 AM
MR_F1
MR_F1's Avatar
True, but please keep in mind that the Elise uses a 2ZZ motor, which weighs a scant 115kg. It doesn't get much better than that, especially if as the article claims it will have turbo hardware. Displacement isn't always indicative of engine weight.
Last edited by MR_F1; 06-09-11 at 05:03 AM. Reason: updated accurate weight number
MR_F1 is offline
Old 06-09-11, 05:28 AM
Blackraven
Blackraven's Avatar
Well, I humbly disagree because I believe that rotary engines have potential
Blackraven is offline
Old 06-09-11, 06:03 AM
JessePS
JessePS's Avatar
Not a typo... I would rather have it be FWD. Way more fun in the winter Small and light... I'd be flying everywhere
JessePS is offline
Quick Reply: Next-generation Mazda Miata could be lightest version ever , 1,800 LBS
