Traction control on the IS in the severe winter weather
Hello,
I am looking at the IS 250 (2014), and debating whether or not to get AWD. I was wondering how good the traction control is on the IS 250. I do plan on getting a set of good severe weather winter tires (e.g. Hankook W419 or X-ice).
As long as the traction control is good enough to save the car from a spin, then I'm golden. (Obviously, it won't save me from every spin). For example, I'm gunning it on a straight old & go over a big bump, will traction-control save me from a spin?
Thanks in advance,
Gnt
edit: I looked around the Canada forum, but couldn't find what I was looking for.
Thanks in advance,
Gnt
Traction control and ABS don't make you accelerate and brake better.
Those are just features for drivers don't know their vehicle's limit.
I found traction control annoying.
And I brake better without ABS...using threshold brake.
Thanks for the reply. I'm aware of the limitations of the electric systems & the driver is what matters. I'm just seeing if the traction control is good enough so save me from a spin if I am caught off guard (such as a big hump in the road).
With that being said, an additional question: How close to the car's limits can I push before the traction control kicks in.
edit: Found another thread that explains the techniques used by the system http://my.is/forums/f89/how-does-tra...l-work-438818/
i found this stupid winter... for my RWD IS350 a good set of winter tires, bucket of sand, shovel, carpets and turn off traction control fully is your best way, especially in the snow
I own an IS250 manual RWD, Hankook winter tires.
If you drive properly you can drive anywhere in GTA easily. I even went to blue mountain during the snow storm and I was fine. It's an amazing car.
BTW my IS250 is the 2nd generation. The 3rd generation should have better control.
ohmike
02-16-07 04:10 PM
