Build Threads Details on Club Lexus 1IS owner vehicles
Xs-power new is300 sc300 supra na turbo kit review and install 2014
Old 02-23-15, 05:29 PM
is300turb0
is300turb0's Avatar
Default Xs-power new is300 sc300 supra na turbo kit review and install 2014
Hey I am building my 02 5spd is300 mainly to have a quick reliable daily. I just bought a XSPOWER turbo kit and I have to say looking good.
XSPower t4 T61 turbo:
The turbo is perfect size I think for my goals. However about the turbo's quality the turbine is solid no play or rubbing.
XSPower turbo manifold:
The manifold looks well put together the welds are solid and great supports.
XSPower intercooler:
It is a double core front facing intercooler welds looking good.
XSPower downpipe:
The main thing that really got me excited is that the dp came with the 2 o2 sensor bungs and a a/f gauge bung so I don't have to worry about getting it welded. As well as v band clamps.
XSPower Wastegate:
The waste gate looks exactly as the HKS one and seems to be pretty good quality.
XSPower BOV:
It is a Greddy replica that also seems to be pretty good quality.
Osidetiger custom 660cc injectors:
These are genuine Bosch remanufactured with a one year warranty and guarantee.
The kit came with everything I need to install.
So far I am really impressed with the xspower kit and their customer service is great, it is at a great price, and good quality can't wait to install.
INSTALL
The xs power kit had all the parts I need to make this install in one weekend.
Turbo Manifold install I had to move the brake lines slightly just makes sure the turbo doesn't rest on on them.
Xs-power new is300 sc300 supra na turbo kit review and install 2014-vc2zok0.jpg
Xs-power new is300 sc300 supra na turbo kit review and install 2014-9tugeqw.jpg
Turbo install, I found it easier to install the turbo and the manifold together and then putting on the engine because those bolts on the turbo are in tight places.
Xs-power new is300 sc300 supra na turbo kit review and install 2014-s1p4kh2.jpg
Intercooler install, the intercooler brackets are installed on the inside of the crash bar just loosen the nut, put the bracket on and on the intercooler, then tight it all down.
Xs-power new is300 sc300 supra na turbo kit review and install 2014-rwxvl6i.jpg
Oil feed line, The feed line I ran to the oil pressure switch where I teed it off one side with the pressure switch and one side with the fitting for line then the feed line.
Xs-power new is300 sc300 supra na turbo kit review and install 2014-wvj6mdd.png
(I forgot to Teflon tape that's why I have a little drip)
Oil Return line, I took off my oil pan and drilled where the oil return would be on the gte motor (indentations are there). To do this everyone said to drop the sub frame, but I found a new way. Loosen the motor mounts make sure to leave a couple of threads so they don't pop out the holes otherwise you are going to have fun getting them back in. Then use like a piece of wood so there isn't metal to metal contact and jack up the upper pan in between the tranny and sub frame. Then remove the bolts holding the pan in and voila.
Xs-power new is300 sc300 supra na turbo kit review and install 2014-op2frlz.png
Down pipe install, to install the down pipe I found it easier to run it up thru the bottom you will probably need help with this have someone hold the down pipe in place while you tighten the v-band on the turbo. I would install the O2 sensors first before putting it in. Once, you finish you should take your car to a exhaust shop and either weld on a v-band or weld it all together, but if you do that you wont be able to get it out if you need to.
Xs-power new is300 sc300 supra na turbo kit review and install 2014-tcqnh20.png
All that's left is to do all the plumbing, add some oil and your good to go. For oil my tuner recommended that I use 10w-40 Synthetic.
Xs-power new is300 sc300 supra na turbo kit review and install 2014-dt3ghkl.png
Xs-power new is300 sc300 supra na turbo kit review and install 2014-xvsao4p.jpg
Xs-power new is300 sc300 supra na turbo kit review and install 2014-2hldlaz.jpg
Xs-power new is300 sc300 supra na turbo kit review and install 2014-dcaqoqp.png
Here is a video of first start.
I am going to dyno soon and will post a video.
XS power kit has really surprised me for the price. I have been driving for about 4 months now no problem. I just did an oil change and no metal shavings whats so ever. If looking for a good cheap kit look at this one you won't be disappointed.
Old 02-24-15, 06:38 AM
dwhitehead
dwhitehead's Avatar
looks good. How much did you end up spending? What ems are you using? And why did you say to have the dp welded, does it not bolt to stock exhaust?
Old 02-25-15, 05:25 PM
is300turb0
is300turb0's Avatar
After tuning it will be right about 3-4k not bad. I am going with the FIC. I said get the dp welded cause I was assuming you would be running a custom 3" but it does look like it bolts to factory exhaust.
Old 04-13-15, 05:48 PM
CKeff
CKeff's Avatar
Rad! Just what I wanted to see lol
However, the link for the kit leads to the wrong ebay auction, so I went and looked and I couldnt seem to find the XSPower kit, if I'm doing something wrong let me know haha
Old 04-15-15, 06:08 PM
VMRWheels
Former Sponsor
VMRWheels's Avatar
Nice! Look forward to seeing how it does on the dyno
Old 04-22-15, 10:51 AM
c1l
c1l's Avatar
Looks great i just bought an xspower manifold and downpipe myself. Looks quality!
Old 04-23-15, 09:55 AM
exist3nce
exist3nce's Avatar
Did you end up getting this tuned? How did it turn out? Dyno graphs?
Old 06-22-15, 10:08 AM
c1l
c1l's Avatar
I just got tuned using the same manifold made 742rwhp
Old 06-29-15, 06:53 AM
is300turb0
is300turb0's Avatar
Nice bro! Yea I am hoping to tune Thursday or Friday of this week I just went AEM Infinity 6 so waiting for the install
Old 01-19-16, 05:19 PM
PolarStar
PolarStar's Avatar
Thumbs up
Great review with good info! But did you ever get that tuning down? And if so what numbers?
Old 01-20-16, 05:42 PM
Loda19
Loda19's Avatar
Updates please!
Old 01-23-16, 11:47 AM
nickj718
nickj718's Avatar
I just ordered one
This is the new one. Feel free to pm me with questions
As some of you may know I'm currently underway in my 02 Sportcross turbo build. After researching my options and talking with a few companies I decided to go with the XS Power kit. I actually got to speak with the owner of XS Power and he told me they are rolling out a new design for 2016 and he would let me be the first to receive it.
I ordered the kit and it took just 4 days to receive it. Today i got it and I have to say I'm impressed.
First lets talk about the manifold. Every single weld is spot on each exhaust port is extremely clean, the T4 mount and collector welds are better than my last SRT manifold and its just freaking beautiful to look at.
The downpipe is the same way. It has 3 o2 bungs which is the same as most so you can support your B1S1 B2S1 and wideband sensor. Again welds are perfect and its heavy duty just like the manifold.It features a slight kick to better clear the firewall as well. My previous kit years ago from a different company was always close and I didn't much like that. The pipe is 3" features a v-band for the turbo and 2 bolt to complete the rest of the system.
The best part which I though would have needed ordering is it came with all of the necessary feed lines,fittings,vacuum lines,gaskets,hardwear,manifold and turbo studs, and even the oil feed adapter for the block.
The BOV is a RS style to the Tial style. I used to have a RS on old kit and I gotta say this looks the exact same. Quality is on point and love the v-band. Wastegate is a 4 bolt HKS style and seems good quality as well.
Turbo is a T4 styled after a Garrett GT35. Its oil feed only and has a ar of Compressor wheel (Front) is a AR of.60 and the exhaust side is a AR of .84. Full spool should be right at 3k. I also opted for the turbo blanket which is very nice.
The intercooler kit couldn't be better. The intercooler is nice and big but not so big that its gonna creat pressure drop. The hot side piping is 2.5 and the cold side is 2.75 which is the same as the stock intake tube so it will be perfect for the MAF readings since nothing is changing.
All in all Im impressed.
If you guys need anything or have questions let me know ill try to help. I hope this post helps others that want to boost but not go crazy in power and price. I plan to roll 8-10psi daily which this will have no problem at all doing
Fuel system and management is all thats left when you buy this kit.
File Type: jpg
Old 01-23-16, 07:03 PM
MrJE89
MrJE89's Avatar
very nice!
Old 04-01-16, 11:52 PM
mbueno14
mbueno14's Avatar
Originally Posted by nickj718
I just ordered one
can you post the link to this kit
Freefallin
Performance & Maintenance
03-22-14 10:33 AM
empera
SC400 / 300 Classifieds
23
04-28-10 06:13 AM
nitrous_sc
GS - 1st Gen (1993-1997)
11-15-06 11:53 AM
cw5speed
Performance
02-01-04 03:18 PM
haas
Performance
01-21-03 12:47 PM
Quick Reply: Xs-power new is300 sc300 supra na turbo kit review and install 2014
