My 2jzgte Driftmotion 60-1 Turbo Build
Since I got this SC about a year ago I was contemplating between the 1jz swap, the na-t build, or the 2jz swap.
I went out last week and purchased an Aristo 2jzgte non vvti motor. I'm not sure what made me pick the 2j swap but I'm happy with my decision. The shop I bought it from is in Orlando, Fl which was about an hour drive from me. The shop was called JDM Express and to be honest I'd never heard of them. But they just so happened to get the engine I needed the day I called.
From my hours of research, practically everyone recommended doing the single turbo upgrade while the engine is out of the car. Being a college student I wanted the best bang for my buck. So I called up Aaron at Driftmotion yesterday and he helped me piece together a kit. I was skeptical at first about driftmotion turbos, manifolds, etc... But Aaron seemed confident in his product and most people on the supra and lexus forums had nothing but great things to say. So I guees we'll just have to see how it holds up! Needless to say I started ordering all my parts last night.
Parts Ordered:
1.Driftmotion turbo kit (60-1 turbo, turbo manifold, waste gate, k&n filter, Downpipe, Mid-pipe, Oil Line)
2.Supra Throttle Cable
3. Timing Belt
4. Radiator hoses
5. AEM Wideband and Boost Gauge
6. Power Steering Reservoir
7. CXRacing FMIC Kit w/ BOV
8. Serpentine Belt
9. Walbro 255 Fuel Pump
10. Driftmotion Pulleys
11. Water Pump
12. Front Crank Seal
13. Cam Seals
Parts Needed:
1. Tweak Wire Harness
2. Valve Cover Gaskets
3. Exhaust System
Correct me if I'm forgetting something please! & thanks to Kevin Shockey for helping me a ton!
3. Timing Belt
4. Radiator hoses
8. Serpentine Belt
11. Water Pump
13. Cam Seals
Parts Needed:
3. Exhaust System
You are not going to be able to run the 440 jdm injectors safely, on pump gas, if you want to make over 400hp. Maybe some USDM ones would be OK. Good luck with the build!
Update
Since the swap I've put about 8k miles on the car. Still running great on 19 psi. Unfortunately I don't have any solid numbers on hp. (350-400) Although i do commend driftmotion because their turbo kit is doing much better than i was anticipating. I will be sure to update once more miles have been put on the motor.
Some other key parts I got:
Greddy bcc (sw20)
Hks dli (jza80)
Tein SS coilovers
Megan racing traction rods
My plans for the future include:
Mk4 LSD+ds
R154 swap
Ls400 bbk
Bigger injectors (?? Size)
Also, I've got a set of rpf1's and a sc400 oem lip put on for looks. I'm sure I'm forgetting a few things but you get the point. Still plenty too come!
P.s. I post a lot of updates on Instagram about my car. @jesh_whatsa2jz
Greddy bcc (sw20)
Hks dli (jza80)
Tein SS coilovers
Mk4 LSD+ds
R154 swap
Ls400 bbk
BlackoutGS
Performance
224
04-06-20 11:38 PM
