Build Threads Details on Club Lexus 2IS owner vehicles
Headlight auto leveling
Old 01-02-14, 11:11 PM
rohanstar
rohanstar's Avatar
Default Headlight auto leveling
Does every ome headlights have auto leveling capabilities or some stays still ?
I was in the process of purchasing 07 ome headlights and in the description it says "without auto leveling"
does that mean it cant auto level or the seller just dosnt sell it with auto leveling parts ?
Thanks
Old 01-03-14, 09:23 AM
lysis250
lysis250's Avatar
If they are hologen then they don't have AFS but if they are HID then they have to have it.
Old 01-03-14, 09:54 AM
Jeff Lange
Keeping it Real
Jeff Lange's Avatar
AFS is the swivel, auto leveling is something else (though they are both controlled by the same ECU on the car, and they are equipped together).
To answer your question, none of the halogen headlights have auto-leveling or AFS, 2006-2010 HID headlights have auto-leveling and AFS and 2011-13 HID headlights have auto-leveling and no AFS.
Jeff
Old 01-03-14, 11:44 AM
rohanstar
rohanstar's Avatar
Jeff
i thought halogen came standard thats what my 07 had before i swap them out and tthats with auto leveling.....
i currently have auto leveling on my 07 and previously changed out the bulbs to HID all i want to do is change the lens their discolored need some new ones but still keep auto leveling feature.....dont have money for 2012 update whats my best bet ?
Old 01-03-14, 01:08 PM
Jeff Lange
Keeping it Real
Jeff Lange's Avatar
Halogen is standard on all 06-10's and on 11-13 IS250's.
Halogen has never had auto-leveling on any year.
If your car didn't come with HID's from the factory, your car does not have auto-leveling.
Jeff
Old 01-03-14, 04:15 PM
rohanstar
rohanstar's Avatar
Jeff
since halogen is standard,
i didnt get it with DHID'S but it has auto leveling, i installed a HID kit
to my understanding you saying it has to came with DIH'S to have auto leveling feature ..correct ?
i just need some help buying the rite headlights,
basically i should just get ones with AFS rite ?
thanks
Old 01-05-14, 11:24 AM
Jeff Lange
Keeping it Real
Jeff Lange's Avatar
If your car came with halogens and you buy the ones with AFS/Leveling, they will not be the same as you have now, they will use D4S bulbs and have build-in ballasts instead of using H11 bulbs without ballasts.
They are very different headlights (even aside from what I already listed, they have the AFS motor, the leveling motor, and additional horizontal alignment adjustment).
Can you take a picture of the back side of your headlight? I can tell you have you have if you do that, or PM me your VIN and I can check that way.
Jeff
Old 01-05-14, 12:26 PM
Lex_Giorgio
Lex_Giorgio's Avatar
Jeff
Is it a simple add-on though? As in just swapping the head lamps out or would I have to run new wires, change the ecu, etc.
Old 01-05-14, 08:16 PM
Jeff Lange
Keeping it Real
Jeff Lange's Avatar
Your car wouldn't have any of the wiring for the AFS or Auto-Leveling if it didn't come with it, nor the ECU that controls it, or the front and rear suspension sensors.
Jeff
Old 01-05-14, 08:57 PM
Lex_Giorgio
Jeff
lol that idea is out the window haha!
Thanks!
Old 01-06-14, 09:54 AM
rohanstar
rohanstar's Avatar
Jeff
I have build-in ballests installed when I switched out the stock bulbs
And I will pm my Vin too much work getting to the back of headlights
EvilJoker
02-07-19 02:34 PM
GSsportD
18
02-16-17 07:37 PM
BIGMerle
Lighting
06-14-13 10:06 AM
LALEX1
03-20-11 12:51 AM
Quick Reply: Headlight auto leveling
