Hey Kyle, where did you get the leds for the reflectors at? Can you provide some details... Thanks!
Originally Posted by LOLM3
I finally got around to replacing the reflectors with LEDs so now it looks much better and functional. I also just got the Wald diffuser. Better/proper pictures will be uploaded soon.
Yeah I still have it and am actually about to sell it since I just picked up a Wald.
The wiring would be great! i'd assume you just ran it through the trunk liner to the brake wiring.
You do not have to run it through the trunk liner (not entirely sure how that works anyway since the trunk opens).
The brake lights can be tapped into right behind the rear bumper cover--this is what I did and everything works perfectly: both reflectors tapped into one brake light.
You will find a black grommet that will allow you to feed the wiring from the reflector to the brake light harness.
You will see on your tail lamp harness three wires (green, green/white and black/white)
So the wiring goes Tail Lamp Harness <---> Reflector Wiring
Solid Green <---> White (Enables Running Light)
Green and White <---> Red (Enables Bright Mode)
Black and White <---> Black (Negative)
I even took the liberty in wiring the reflectors on the Wald diffuser too lol It might be excessive, but at least people will see when I brake.
^^^^^^ really cool wiring the wald reflectors.
Did you replace the reflectors with LEDs ?
Details please.
I found them online, I measured the reflectors and they are 2.25" which are the same size as the Toyota Sequoia/Highlander reflectors so I found a that there is a set of SMD LED reflectors that are made for the Toyota Sequoia/Highlander so I just swapped them and wired them up.
Very cool. I love when things are functional. Nice job.
I approve
