StillRolli back with a build thread
Nothing to exciting but getting somewhere with my new 95 sc300. Heres a rough list :
Swapped from a dusty old OBD1 2jz GE with 240xxx to a OBD2 2jz still GE... with 140xxx getting all the tune up goodies for it $500. Picked up two high beams and the right headlight at the yard for $50. Did a full 5 speed swap for $600, pick up a 3 inch straight pipe for $50. Got a nice lip for $20! And about to put on megan springs that i also got for $50. Just some basics till funds arent as tight. Still need some interior tlc, and the exterior could use a respray which i get to later. Ill be posting more as a i continue the build. Will be posting pics shortly
Started it up today and had a small leak of gas coming through the exhuast manifold from cylinder one. I think it is the ecu so i am taking off the obd 2 ecu and obd 2 maf, and switching it out with obd 1 ecu and obd 1 maf. Hopefully that does the trick.
