Build Threads Details on Club Lexus SC owner vehicles
8052JZ's NA-T Build
Old 03-04-13, 01:05 PM
  #121
GotRiceYo
GotRiceYo's Avatar
not to shabby my friend! looks good
Old 03-07-13, 08:53 AM
  #122
8052JZ
8052JZ's Avatar
Finished up the A pillar pod while I’m waiting on ****> aem gauges, boost solenoid and quick lock fittings for vacuum wastegate lines, welded up intake pipe, meth tank
Anyway here are the final pics of the pod
Bondo/fiberglass and lots of sanding until it was pretty smooth all around
Fiber glassed in some screws so I can bolt them in from the inside
After I was happy with it, I sprayed some undercoating to give it that pressed plastic look
Than shot it with SEM GM black paint. Not sure if I like how it turned out. Might use Trim paint, the same paint I used for the radio/gauge bezel. Last few pics the paint wasn’t completely dry that why there are "wet" spots.
Attached Thumbnails 8052JZ's NA-T Build-img_2589.jpg   8052JZ's NA-T Build-img_2591.jpg   8052JZ's NA-T Build-img_2609.jpg   8052JZ's NA-T Build-img_2610.jpg   8052JZ's NA-T Build-img_2611.jpg
Old 03-07-13, 08:54 AM
  #123
8052JZ
8052JZ's Avatar
and last two...
And again thank for all the kind words towards my build and work much appreciated
Attached Thumbnails 8052JZ's NA-T Build-img_2613.jpg   8052JZ's NA-T Build-img_2614.jpg
Old 03-11-13, 10:44 AM
  #124
8052JZ
8052JZ's Avatar
sneak peak of whats to come in the next few weekds along with the polished BBK setup
Old 03-19-13, 03:48 PM
  #125
8052JZ
8052JZ's Avatar
Man no love with all these pics i post... tough crowed
Anyways, got a few more things done..
installed an areomotive FPR forgot to take pics..
AEM boost solenoid installed with push lock lines and wired to the aem
2qt meth tank mounted.. Had a 4qt but was to big to fit where i wanted it. I also had to relocate the over flow tank.. There’s a bar I mounted under there to mount the tank.. Can’t see it goes from one side of the car to the other.
All new AEM gauge sensors installed and wiring routed to the cabin. Water, fuel and boost pressure. For the boost pressure I used the egr block off plate and tapped it to except the sensor. Don’t worry I removed that egr tube thing that was inside the intake.
Still working on completing the gauge and meth wiring.
I also made a new IC intake pipe to add the meth nozzles and relocated the BV near the intercooler.
Attached Thumbnails 8052JZ's NA-T Build-img_2623.jpg   8052JZ's NA-T Build-img_2625.jpg   8052JZ's NA-T Build-img_2643.jpg   8052JZ's NA-T Build-img_2656.jpg   8052JZ's NA-T Build-img_2658.jpg
Old 03-19-13, 06:46 PM
  #126
GotRiceYo
GotRiceYo's Avatar
Nice progress! Liking what I see!!
Old 03-20-13, 08:05 AM
  #127
8052JZ
8052JZ's Avatar
Thank you sir! Hopefully ill have all the wiring done tonight for the new gauges
Old 03-20-13, 08:40 AM
  #128
99SC42
99SC42's Avatar
Looking great keep it going!
I am a little paranoid about those meth kits! lol
Old 03-20-13, 09:22 AM
  #129
8052JZ
8052JZ's Avatar
HHHMMM why so? read up on some good results and hardly ever anything bad..
Old 03-20-13, 10:40 AM
  #130
99SC42
99SC42's Avatar
I've read alot of bad stories on SF and that scared me away!
Old 03-20-13, 12:23 PM
  #131
8052JZ
8052JZ's Avatar
haha uh ooo! but most lickly those cars are boosting in some hi numbers.... im only going for around 14psi with 50/50 mix.. should be ok if its setup correct
Old 03-20-13, 01:01 PM
  #132
t4l
t4l's Avatar
Hadn't seen this thread before. Very nice work!!
Old 03-20-13, 02:31 PM
  #133
8052JZ
8052JZ's Avatar
Thank you! More to come...
Old 03-25-13, 08:52 AM
  #134
8052JZ
8052JZ's Avatar
ssooo now she wont start...... Need to mess with a few things as it got to late last night but hopefully tonight ill get it figured up.
Old 03-25-13, 08:57 AM
  #135
1JZPWRD
1JZ Single SC400
1JZPWRD's Avatar
I like those wheels. I also had those tires, Falken FK452, and they were so noisy. I had to go with something else, plus they hated negative camber. Well, what tire does?
What do you think the problem is? In why the car want start now?
Keep us posted and let us know what you figure out, Richard.
Quick Reply: 8052JZ's NA-T Build
