Build Threads Details on Club Lexus SC owner vehicles
8052JZ's NA-T Build
Old 11-06-15, 09:20 AM
  #931
8052JZ
8052JZ's Avatar
Originally Posted by lexforlife
Engine bay is beautiful... I need to get off my azz and do the vvti cop as I have one of those billet dizzy caps as well since last year
the CPs setup is very nice and cleans it up a little bit. Just make sure you have a decent CPS or it wont realy work. I had to adjust the magnets inside to they are closer. Also cleaned up any rust for a cleaner reading. Haven't had issue with it sense.
Originally Posted by HiPSI
When are you going to run her at the track with the new TH400 setup?
Well I hope to run it soon, just working out the tune right now. I need to order a dry NOS kit so I can hold the converter at 16psi for launch.
Going on vacation next week and the day I get back I have to fix an exhaust leak from head to manifold. When i tighten the studs, they are pulling out from the head So i have to pull the turbo and manifold and heil coil those two holes. Not sure how and why this happened but not much I can do about it. After that I should be good to go for the track. The closest one to me is about 3 hours away so its more of planning a weekend trip to the track.
Old 11-06-15, 10:04 AM
  #932
Ali SC3
Ali SC3's Avatar
I would do the cage first and then paint, cage work might scratch up the new paint if you do it the other way.
Instead of Heli-coiling it, consider going to the next size up metric so from m10 to m12, and then using m12 hardware on those or they have step down studs from m12 to m10.
Some will swear by helicoil, others say to go the next size up, you can research more on it.
Old 11-07-15, 04:50 AM
  #933
lexforlife
lexforlife's Avatar
Originally Posted by 8052JZ
the CPs setup is very nice and cleans it up a little bit. Just make sure you have a decent CPS or it wont realy work. I had to adjust the magnets inside to they are closer. Also cleaned up any rust for a cleaner reading. Haven't had issue with it sense..
Question, what magnets are you referring to.. aren't you using stock dizzy base ..
Old 11-16-15, 11:16 AM
  #934
8052JZ
8052JZ's Avatar
Well I bought the heil coil kit but didn't use it because a local shop told me to use a Time-Cert instead as they are much stronger. Instead of the springy coil its a full thread sleeve that goes into the hole.
When you open up the the 7m CPS there are a few magnets inside there that can be adjusted. Clean those up and move them as close as possible with out them touching. I used a piece of paper to make the gap as tight as possible.
Old 11-16-15, 11:19 AM
  #935
8052JZ
8052JZ's Avatar
Here is all the turbo things off. You can see where runner #6 was leaking pretty bad.
Now with the Time-Cert in the studs go back in and hold great.
Instead of using silicone like the last time I put in a metal exhaust gasket, tighten it all down and its now its good to go. No more ticking exhaust leak.
Old 11-25-15, 10:21 AM
  #936
8052JZ
8052JZ's Avatar
Well since the car is runing fairly good, I think ill start posting what I've been doing on the side.
NEW MOTOR! quest to 1200hp... I hope
GE Block
Corrilo HD Rods upgraded pins and hardware.
Wiesco GTE Forged Pistons with upgraded pins
Program billet main caps and ARP main studs
Balanced and micro Polished GE crank
625+ ARP head studs
GE Cometic ML Head gasket, Compression ration should be around 9.5
GE Head
Full Race port
GSC S3 big boy Cams
GSC Behive Springs
GSC Valve guids and seals
GSC +1 over Valve's
Titan Adjustable cam Gears with ARP cam bolts
Shimless buckets
Started by collecting all the goods
For the life of me I cant seem to find the pics of the valve train :/ aw well
Old 11-25-15, 10:32 AM
  #937
8052JZ
8052JZ's Avatar
Before Sending out the block i removed the oil galley plugs to ensure the block gets a good cleaning.
Welded an exhaust stud to the galley plugs and wrenched out the front two.
Than poked a rod through the block to get the back two out. Hammered them out.
After dropping off the block, I later received the block machined and internals properly gaped, torqued down and installed.
Onto finishing the block assembly.
Old 11-25-15, 10:37 AM
  #938
gerrb
Super Moderator
gerrb's Avatar
don't you have E85 in your area Richard ? Just wondering why you are not taking advantage of high compression this time ?
Old 11-25-15, 10:40 AM
  #939
8052JZ
8052JZ's Avatar
Installing the head.
Head has been torqued and re-torqued to ensure proper stretch on the studs.
I am missing a bunch of pics but aw well lol
Old 11-25-15, 12:27 PM
  #940
InLyneTrbo
InLyneTrbo's Avatar
Wow, keep those pictures coming :O Looking pretty epic
Old 11-25-15, 01:16 PM
  #941
PaCowboy
PaCowboy's Avatar
Looks bad *** man. I'm with gerrb if you got e85 local go higher compression and take advantage of it. I wish I had e85 local. Lol. I ain't driving an hour to fill up.
Old 11-25-15, 01:38 PM
  #942
8052JZ
8052JZ's Avatar
I would have gone high compression but my engine builder recommended and convinced me to stay in the 9.0 range. He's built a 2jzge with TRD that made over 60psi of boost back in the day so I took his word. But after seeing that High comp 2j's are becoming more popular with great results, I too wished I went high comp. But than again, these are GTE's motors running high compression. I haven't really seen much about the GE and high compression.
E85 is about a 40min drive for me. I have a 30 gallon barrel I truck to the station to have filled along with a couple 5 gallon tanks. Usually the almost 50 gallons of fuel will last me almost 3 weeks depending how much fun I want to have on the weekends.
Old 12-03-15, 08:34 AM
  #943
8052JZ
8052JZ's Avatar
Stripped the interior out of the car to make way for the Fab guy to build the cage. Dropping her off tomorrow night so he can get started and be ready buy next week!
Now is a good time to clean up the carpet. Hopefully the rear seats can be put back in to cover everything up. It is pretty loud inside the car now with having the interior out.
You can also see how I store my e85. I got a 55 gallon drum the other day to go with the 30gallon drum. When I filled them up it was about 90 gallons of fuel.
Old 12-03-15, 08:38 AM
  #944
TLDriver
TLDriver's Avatar
I wanted to go up there again to see what he said about doing multiple cages, but I am going to be stuck at work until late. Don't forget the alt pulley.
Old 12-03-15, 09:55 AM
  #945
8052JZ
8052JZ's Avatar
I think Jim is coming and we will discuss with the fab guy about that.
Forgot about that pulley already lol
Quick Reply: 8052JZ's NA-T Build
