Build Threads Details on Club Lexus SC owner vehicles
8052JZ's NA-T Build
Old 01-15-15, 02:18 PM
  #751
PaCowboy
PaCowboy's Avatar
That's a good description. I have some Union welders from where I work teaching me how to mig and tig. They had a similar general breakdown of it. Btw real nice setup!!
Originally Posted by 8052JZ
Tig welding is best for aluminum, stainless steel and any other metals. When it comes to wanting perfect penetration of the metals, you would use a Tig in most cases. Mig welding is ok but its a rough finish and mostly used for Steel.
Old 01-16-15, 09:36 AM
  #752
CatManD3W
CatManD3W's Avatar
Where did you send the BW turbo to get the modified larger wheel
What does it take to turn the s366 into a 71mm or 73mm compressor wheel
Old 01-16-15, 09:44 AM
  #753
8052JZ
8052JZ's Avatar
Its definitely a handy trademark to know.
I go to Apex Performance Turbo's that is local to me and also a buddy of mine. He does great work at a reasonable price. I believe he bored out and re sleeves the compressor housing to make the 71mm fit. Give him call and he will give your break down.
Old 01-21-15, 08:54 AM
  #754
8052JZ
8052JZ's Avatar
Everything is mostly all back on the car and ready to run... I just need to make the 5.5" intake pipe for the turbo and fix the midpipe.. Somewhere along the lines of modifying the down pipe, things got a little tweaked.
Instead of using a metal gasket, i used ultra copper gasket maker to seal up the manifold. Apply, hand tighten and let set for 1 hour, than torque to spec.. Should work nicely
And same quick picks I took around 11pm when I finished assembling.
Old 01-21-15, 12:09 PM
  #755
MacGyverQu
MacGyverQu's Avatar
Looking AMAZING. You've inspired me to upgrade my welding setup and add a TIG at some point. Keep up the great work.
Also never thought about using the copper gasket maker vs the steel gasket.
Old 01-21-15, 03:35 PM
  #756
8052JZ
8052JZ's Avatar
^^^ Thank you! Hope to have her running again tonight. Check for leaks if any, than fix the midpipe if I have enough gas to do so..
Old 01-21-15, 04:12 PM
  #757
gerrb
Super Moderator
gerrb's Avatar
Richard , what size is that turbo ? Is that the 80mm ? It looks huge !
Old 01-22-15, 07:41 AM
  #758
8052JZ
8052JZ's Avatar
Its a s471 with the race cover. The race cover makes the turbo look massive...
BTW got her fired up last night and all seems to be ok. I think I need to add fuel to the fuel map sense this is a bigger turbo and a new manifold. At operating temp she runs at 13.4 afr at idle.
Old 01-22-15, 08:14 AM
  #759
8052JZ
8052JZ's Avatar
Here is a crapy video of the car running. I wasn't really paying attention to filming sense this was the first start with the new setup.
Old 01-22-15, 10:17 AM
  #760
CatManD3W
CatManD3W's Avatar
Do you need to run a 5" intake with that compressor housing?
Old 01-22-15, 11:01 AM
  #761
8052JZ
8052JZ's Avatar
what do you mean by need? lol its actually 5.5" I was able to find an aluminum straight piece that I will cut and weld to fit nicely.
Old 01-22-15, 11:07 AM
  #762
8052JZ
8052JZ's Avatar
Few pics of the turbo side..
Old 01-22-15, 03:26 PM
  #763
Ali SC3
Ali SC3's Avatar
I think you just won the closest to shock tower and cps without touching them award.
Old 01-22-15, 03:31 PM
  #764
HiPSI
HiPSI's Avatar
Old 01-23-15, 08:53 AM
  #765
8052JZ
8052JZ's Avatar
Originally Posted by HiPSI
It is in deed close but it fits
Quick Reply: 8052JZ's NA-T Build
