Build Threads Details on Club Lexus SC owner vehicles
8052JZ's NA-T Build
Old 07-16-14, 02:36 PM
  #676
gerrb
Super Moderator
gerrb's Avatar
oh shoot.... that is an inch out for the rear wheels..
roll and pull those rears.. should get 50mm and be able to install 345 in the future when those tires are gone after 5k miles. And would allow you to lower it more. For the fronts, I was able to get 25mm more after rolling ad pulling them.
Old 07-17-14, 03:10 PM
  #677
8052JZ
8052JZ's Avatar
Before the corner balance the wheels sat nice an flush but with lots of camber. Now that it's pretty much at 0 degree's camber they do stick out. But regardless if them sticking out the car drive's amazingly! The drivers side sticks out a tad further than the passenger side and is a bit higher. I believe it's setup this way to compensate for the driver. But I may lower it to match the passenger side and to bring in the wheel a little than try an pull the rears.
All the fenders are rolled already so I'll need to pull them for sure but I have no idea on how to do so. Is there a write up on how to pull these fenders on our cars? Gerry I know you've done it so I'll shoot you message an maybe you can give some pointers with pics along with what tools to use.
Old 07-17-14, 03:58 PM
  #678
gerrb
Super Moderator
gerrb's Avatar
This is one of the best tool I ever bought , a portable hydraulic kit I used to push those front fenders out.... cheap but a lot of uses.
http://www.harborfreight.com/4-ton-h...kit-44899.html
Just pulled my front fenders and got another 25mm clearance . At the rears I got 50mm more clearance when I did them some time back . It now enables me to use 13" rims and 345" wide tires .
Old 07-18-14, 10:35 AM
  #679
8052JZ
8052JZ's Avatar
hhmm what else is required to make this happen Any cutting? the biggest concern I have is to not get the panel wavy or have the paint crack sense I wont be doing paint until sometime late winter. With the car being black, it shows almost ever little flaw and detail in the body :/
Old 07-18-14, 11:47 AM
  #680
gerrb
Super Moderator
gerrb's Avatar
depending on how much clearance you are trying to get... paint may crack. I did go for the maximum I can get from a stock body. 50mm rear and 25 front .. which is basically what the usual wide body kits give you and enable you to use a lot wider wheels and tires.
here is my rear .. that wheel has a 22mm offset which was 25mm out before the pull and now is 25mm in after the pull. With the right wheel and offset , I should be able to fit 13" wheels and 345 tires now. As is right now I have at least 2.5" clearance from my stock shocks / inside wheel well that is why I said I can now fit 13" wheels and 345 tires if I go MKIV TT offset which is 50mm and coil overs.
Old 07-18-14, 12:11 PM
  #681
8052JZ
8052JZ's Avatar
Man that looks great! but I'm guessing you did some body work afterwards?
Did you have to cut anything on the inside of the wheel well are you just used the hydraulic ram and pulled them out?
Old 07-18-14, 12:45 PM
  #682
gerrb
Super Moderator
gerrb's Avatar
For you to get 50mm , you will need to cut the inner wall ... you push that fender outward .. then re-weld the inner wall you cut . You won't get much if you don't cut that inner liner cause it will be fighting your pushing out action and if you don't cut that inner wall , you will only be able to push the tip .. you won't get a good arch making it look like a stock flare.. which it does right now. I believe in one of the pages of my build thread I documented the job when I flared my rear quarter panels. I just don't remember which page.. hahaha.
Then you will have to do some body work for sure cause you will have crack paint and some waves. Yes I did some body work and still doing some of it now , trying to fix small dings and dents before sanding it all for painting.
Here is a picture of the driver side. You can actually push that fender out starting from the bottom of the body line.... only if you cut that inner liner. Looks like an OEM Fender flare ...again best done before any painting of the car is done.
Old 07-18-14, 01:00 PM
  #683
8052JZ
8052JZ's Avatar
Sounds scary lol I guess ill have to leave it for now until I pull the trigger on getting body an paint!
The weird part is that the passenger side doesn't stick out all the far compared to the drivers. It might be because its about a half inch higher on the drivers side.. I could lower it but than ill have one side that has slight camber than the passenger side that's at Zero.
Old 07-18-14, 01:17 PM
  #684
gerrb
Super Moderator
gerrb's Avatar
Well if you only need a tad of pushing out... you can do the tip and do it slowly so there is no paint cracking and no need to cut the inner liner . I just went for the max clearance for a stock body since I would eventually like to have 345 tires once my 315 are gone without going wide body.
Old 07-23-14, 08:06 AM
  #685
8052JZ
8052JZ's Avatar
Guess ill have to give it a try! But I think ill pull them when paint an body comes around!
Old 07-23-14, 08:12 AM
  #686
8052JZ
8052JZ's Avatar
Got the manifold and started to work on it last night. I cut off the original wastegate section and plugged it up so I can add the two ports right underneath the T4 flange. Its nice that this is an open scroll manifoldbecuase you can run a QSV with this.
Cut this off with a plasma cutter because the location is terrible.
And plugged it up with a heavy beed.
Old 07-23-14, 10:01 AM
  #687
HiPSI
HiPSI's Avatar
So was it creeping as is? Or you are just modifying it first for good measure?
Have you test fitted the manifold yet? I'm curious of the position / height of the turbine housing in relation to the intake manifold if it's usable on with the stock throttle body and smaller turbine. I know the BW setup the turbine is alot larger so it's harder to gauge if it will work.
Old 07-23-14, 11:09 AM
  #688
8052JZ
8052JZ's Avatar
This is the new manifold that I am modifying for two waste gates the proper way. Not sure if if this manifold will creep or not but not just the direction of flow going to the gate doesn't make any sense. Maybe it works as is but not risking it.
The position/height of the manifold is very similar if not nearly identical to the ebay/xspower manifold out there. Wont be for a month or so until I get this manifold in the car. Until than, ill be sure to take a few pics.
Not sure if this helps but this is on my buddy Jim project. that was a qsv and a S400 series turbo I believe.
Old 07-23-14, 12:02 PM
  #689
Kris9884
Kris9884's Avatar
Nice, I just noticed your alternator. I assume you upgraded AMPS and is now using the typical Toyota plug for newer model cars and probably not the same as the one on your harness. Obviously you know a thing or two and its not important at this moment but just in case I can save you any time, get a plug from a Camry or 4Runner and solder it on, then it's plug and play.
Edit: Here's my post with the small write up just in case - https://www.clublexus.com/forums/8628625-post4570.html
Old 07-23-14, 12:13 PM
  #690
8052JZ
8052JZ's Avatar
Originally Posted by Kris9884
Nice, I just noticed your alternator. The plug on yours is the typical Toyota plug for newer model cars and probably not the same as the one on your harness, obviously not important right now but when the time comes, get one from a Camry or 4Runner and solder it on, then it's plug and play.
Its still plug an play. Jim's car is the model that had the alternator plug come off the body harness on that side. When I did his harness along with mine the alt plug was part of the engine harness. On my car I left it alone and with his harness I removed the alt plug from the engine harness and the factory alt plug alone.
Two types of alternates used in certain years in the SC. Oval plug that's on top and circular plug that's on the back of the alternator. I think 94 or 95 and up have the oval plug.
Quick Reply: 8052JZ's NA-T Build
