1jz vvti build....flippy dipping finnaly!!!!!
#46
Just FYI
#47
All the blocks have that only on the 1jz they have that nipple on there. On the 2jzs they have the same exact bolt with w/o that nipple.
So they all have the 14mm bolt to drain the block at the same location only difference is 1jzgte have the nipple on it.
#49
big update guys, dropped the motor in last sat, mostly everything is hooked up except for a few things. On to the pics!!!!!
#56
Anyone runnin water wetter in there coolant? And is it ok to run radiator flush on a turbo motor? Or will it burn out the seals like oil flushes do? Or just run straight water then drain and add the coolant?
#58
Ok guys, went to go start her, and I have no power what so ever, only interior lights work, and door chime, that's everything else no power. It's a 1jz vvti out of a soarer into my 95 sc300 5mt
#60
My multi meter said 12.02 battery has been out my car for a 2 months now, so maybe it is dead, ill try and jump it tomorrow, but I have a feeling its not the battery
