Build Threads Details on Club Lexus SC owner vehicles
2jzGTE SCs - The Siblings of my Supra MKIV Toys
Old 06-07-12, 03:22 PM
  #751
gerrb
Super Moderator
gerrb's Avatar
The filter after the pumps fitted into the bulkhead on the trunk ...
Old 06-07-12, 03:24 PM
  #752
gerrb
Super Moderator
gerrb's Avatar
installed the -6an to -10an fittings into the fuel log ... and the pre-filter of the big pump
Old 06-07-12, 03:27 PM
  #753
gerrb
Super Moderator
gerrb's Avatar
started laying out the fuel system ..some change of plans. Instead of installing the fuel log and big pump on the righ rear end of the trunk, I have decided to install them above the fuel tank. In that way , my trunk will still look clean and I won't see any fuel lines when you open the trunk.
I am planning to bolt the pump and fuel log into the cross metal bar above the fuel tank there in the trunk .. though I will install them with a padding against the cross bar so when the pump is on , it wont be vibrating agains that wall.
Old 06-07-12, 03:28 PM
  #754
gerrb
Super Moderator
gerrb's Avatar
Did the teflon line for the outlet of the big pump that feeds the fuel log
  #755
gerrb
Super Moderator
gerrb's Avatar
The big pump feeding the fuel log
Old 06-07-12, 03:32 PM
  #756
gerrb
Super Moderator
gerrb's Avatar
just to help the newbies in doing the braided lines .. you first cut the line and insert one part of the fitting
then spread out the braided cover
then insert the brass ring
and now the end part
Old 06-07-12, 03:34 PM
  #757
gerrb
Super Moderator
gerrb's Avatar
Did the first TT Denso pump feed into the fuel log
  #758
gerrb
Super Moderator
gerrb's Avatar
and then the second feed from another TT Denso pump into the fuel log
Old 06-07-12, 03:36 PM
  #759
gerrb
Super Moderator
gerrb's Avatar
Got the big pump and two TT Denso pump line feed to the fuel log done ...need to do another one .. I hate these smaller braided lines.. harder to do .. your fingers getting pricked every now and then
Old 06-07-12, 04:23 PM
  #760
gerrb
Super Moderator
gerrb's Avatar
Just got the 3rd TT denso feed to the fuel log done
Old 06-07-12, 04:24 PM
  #761
gerrb
Super Moderator
gerrb's Avatar
now need to work on the -8an return line from the trunk bulkhead to the fuel tank . I am trying to decide wether to use that teflon line coming out of the fuel log that has summit racing fittings or make another one using the right teflon fittings... I used that line in my Supra before , it was good and no leaks.. maybe for now will try to use it and see how it holds..
Well .. got to go back to the garage .. dinner is over and continue working on those teflon lines going to the bulkheads on the trunk ... sh&t , my fingers are aching due to the so many ****** from those braided lines...
Old 06-07-12, 05:43 PM
  #762
gerrb
Super Moderator
gerrb's Avatar
Decided to put the tank in the trunk so I can better see what kind of bracket I need to do for the fuel pump and the fuel log ...
I guess I would need to take out the two side speakers . Afterall I would install a customized sound system for this car .
This is how it will look more or less in the trunck. With this layout , I can put back all my trunk mattings , sidings and carpet and my trunk will still look clean without seeing any of those plumbing ...
Old 06-07-12, 05:47 PM
  #763
gerrb
Super Moderator
gerrb's Avatar
shots from another angle .. am glad , the idea of installing them above the tank came out ..
Old 06-07-12, 05:49 PM
  #764
gerrb
Super Moderator
gerrb's Avatar
These will be the return and feed line on the bulkheads going out of the trunk .. filter after the fuel log ...
Well , I guess my Red Dragon can spew fire as much as she wants with all the BOOZE it will be getting from the fuel system. a lot of alcohol (E85) .. I believe my fuel system is capable of supporting 2500+rwhp on race gas and 1750+rwhp on E85 ... much more if I decide to install the Weldon Pump from Darin's car which I got for a very good deal last night on Supraforums.
Damn, not even my stroker Supra got this much . Both my supra only have the Weldon 2345a pumps.
Is it OVERKILL ?
As our friends around here say .. there is no over kill on fuel system. Though I believe I will only turn on pumps based on need (e.g. boost based , kill mode ) so I don't uselessly overheat the fuel . On cruise mode , just one Denso pump , then at around 15 psi .. two Denso pumps and three Denso pumps above 25 psi . The big pump will turn on based on fuel pressure on each TT denso line ... a fuel pressure sensor will be installed on each TT denso line and on the main line... If one goes low meaning the pump goes dead, the big pump should turn on. At the same time , I will wire it in such a way that with a flip of a switch , it will turn on also for kill mode just like that of the weldons with the controllers .. Damn I hope I find the right ECU that can take care of such situation..
Old 06-08-12, 06:31 AM
  #765
gerrb
Super Moderator
gerrb's Avatar
Before I left this morning.. I figured I might as well make the -10an feed line from under the trunk to the engine bay
Quick Reply: 2jzGTE SCs - The Siblings of my Supra MKIV Toys
