"Biturbo 2JZ swapped' Soarer Build Thread"
#109
I'm sorry I'm late to the party. I wish I would have seen this thread sooner....like a year ago. I could have saved you SOOOOO much time and headache with that wiring harness. Nothing needed changed. You can run a 1JZ harness on a 2JZ, and vica versa just fine. If you had wanted to run a 2J ECU, then all you would have needed to do was buy a PLUG AND PLAY patch harness and away you go! It was THAT simple.
#111
Hahaha!! Go ahead! And good luck btw!
Thanks!
Finally yep! Do you like it?
18inch front and rear.
Exact!!! Achetée en 2008! Il y en avai6t2 lorsque j'ai acheté la mienne! L'autre était blanche, intérieur Tan et transmission manuelle, mais endommagée... donc....
Are you fawking serious? There's a plug and play harness? LOLL epic fail for me! I didn't know that! And yes I wanted to use the 2JZ ecu for the sequential turbo operation.
We have though that running an 1JZ harness on a 2JZ would have left me only with the parallel turbo option. But damn.... the plug and play patch harness.. I don't believe it... made by you?
Btw it was kinda fun to do that, now we "understand" the car and engine a looooooot more!
Thanks a lot!
Thanks!
Thanks a lot!
#113
All the work myself = more, much moooore money in my pocket!
#115
#118
The patch harnesses I was talking about are built by a company called Autosport Wiring. They are high quality, and they have very fast shipping. I do sell them though!
Regardless of the wiring fiasco, your car is beautiful!
#119
Thanks man|
It's nice to know it after all if I plan to do this again!! loll
And thanks a lot for the info and comments!
