Build Threads Details on Club Lexus SC owner vehicles
project:Soarer
Old 03-05-17, 01:37 PM
  #571
megamax
megamax's Avatar
Next up was assembly time. Yes I was nervous as this will be my frist assembly of a bottom end and I can't **** up on this one. so after some youtube videos and some verbal advice from some people I took a crack at it. thankfully some warmer weather came by to help.
so aside from following the fsm, apparently the "big" thing is crank thrust, so I carefully did that and tried to make sure it was within spec
Old 03-05-17, 01:41 PM
  #572
megamax
megamax's Avatar
then it was on to the pis-on-ton loading
went in without a problem, no piston rings were injured!
Old 03-05-17, 01:47 PM
  #573
megamax
megamax's Avatar
next up was head gasket and oil pan/pump install, I have done this before on the thread so I skipped this illustration this time.
YES, the lower 1jz cam cover is too small, and I'm actually selling the set (top and bottom)
ran into an issue with the water neck.
Old 03-05-17, 01:58 PM
  #574
megamax
megamax's Avatar
so I made a FAILED attempt at being a machinist to fix it, I just sourced a n/a one at the junkyard and got that one.
so 20 bucks later it was welded and the crisis was averted.
now the motor was getting ready to "go in"
up next was the r-154 prepping. I opted for this clutch kit, why? because it's cheap and I'm poor.
and I also modded my w58 vss to work.
spent a few nights with no sleep.
I MUST SAY, the hardest thing about this whole tranny thing, was getting this damn bearing together, that snap ring is a mother!
luckily I had a pair of ring(not leg) spreaders and some clamps to make it work.
also had to cut some bolts because the pp ones for the w58 are too short.
Old 03-05-17, 02:04 PM
  #575
megamax
megamax's Avatar
now it's time to mate the 2 and form voltron!!! it was a foggy morning that day.
so finally got around to draining the fluid in the trans to replace it with some synchromesh. But I seen some small metal sheen particles in it.
at this point all I could do was grab my butt cheeks and hope for the best, it was too late now.
I installed the motor and tranny, and surprisingly the trans mount came up to the exact same spot as the w58 did GO ME. used the same shifter I had before the the shifter location hasn't changed.
only thing is I had to make the tranny mount holes bigger.
and yes the ds is a few inches short, still works/fits but u should get it extended.
Old 03-05-17, 02:05 PM
  #576
megamax
megamax's Avatar
and now it's done and done.
Old 03-05-17, 04:11 PM
  #577
gerrb
Super Moderator
gerrb's Avatar
Jim - glad it is all done now . Glad to be of help !
I don't see any reason now why your bottom end won't hold 800rwhp . Those rods and pistons will support the power all day !
Old 03-06-17, 03:50 AM
  #578
megamax
megamax's Avatar
well when I head back upto sp I'm going to use c63 race gas, I want to make good numbers e85 free(I'm old school). I just want 700whp, I have 800cc injectors, prob going to need 1k and bigger fuel lines?
Old 03-06-17, 04:07 AM
  #579
gerrb
Super Moderator
gerrb's Avatar
Your stock lines will only get you to around 500-550rwhp . You will need bigger lines to go higher . I see you prefer race gas . Regardless you will need bigger lines and bigger injectors. 800cc injectors should get you there at 700 on race gas but 1000cc will be better. You don't want to be running close to 100% injector duty cycle . You always want to have room .
the 800cc injectors will only bring you to around 550rwhp on E85. You need 1200cc to have some room if you are aiming for 700rwhp on E85. Keep in mind E85 uses around 30-35% more volume of fuel to get same power that you get from pump 93.
Old 03-06-17, 05:28 AM
  #580
LoveSCs
LoveSCs's Avatar
Great perseverance and comeback story!! Post a video please once you get her tuned and running, I want to hear this thing purrrr. Thanks for all of the specifics too because I will eventually be doing a 1.5 if my bottom end lets go, or if I just want more power lol
Old 05-03-17, 07:50 AM
  #581
megamax
megamax's Avatar
Here is my write-up on cluster swapping..
https://www.clublexus.com/forums/bui...lkthrough.html
Old 05-03-17, 08:09 AM
  #582
megamax
megamax's Avatar
so during this time, I ordered a throttle cable from phr. the cable I had was from a camry and it was longer than I needed and it contributed to the throttle hanging when the plate closed.
so instead of getting a stocker I opted for a shiny ss cable.
https://www.powerhouseracing.com/pro...upra-and-sc300
Old 05-03-17, 08:36 AM
  #583
megamax
megamax's Avatar
sam in customer service was kick *** helpful and I got it quickly. well during my initial installation the cable came loose from the pedal stop. apparently they leave it "not tight" so you can install the oem rubber stop. anywhoo I could not get the cable back through the very small hole.
so I cut up the oem cable to length and drilled out/made bigger the hole like so.
locktite red before i double stopped it.
finished product
and done, added with the cx racing bracket, and later on i brought a brand new oem gte tps, my throttle is spot on.
Old 05-03-17, 10:59 AM
  #584
megamax
megamax's Avatar
and here is my heater core cluster eff.
https://www.clublexus.com/forums/bui...ml#post9856339
NEXT UP FUEL LINES!!
Old 05-13-17, 10:20 AM
  #585
SyckSC
SyckSC's Avatar
Thats a long build but came out nice
Quick Reply: project:Soarer
