why does it look so faded
i wanted to know how come the paint on my daily doesn't pop like it use to before i want to spruce it up and have it shining again deep gloss, do i need meguiars ultimate compound or should i just polish it ? could it be oxidation?
before
now
before
now
It's real simple man.... wash it> clay bar with some slick lube>wax. DONE.
Of you really want to get fancy and get drawn into the world of detailing, you'll find out what paint correction is, what polishes, pads, and compounds, are.... and all that jazz. and next thing you know you are spending thousands of dollars on supplies you are rarely gonna use. ask me how I know.
but your car will be the nicest on the block though....
smh...it's a 14 almost 15 year old car....think how you would look if you stayed out in the sun, rain, and snow for 14 years straight.
I suggest you search through this forum and maybe join up on some dedicated detailing forums as you're asking really basic questions that have been covered time and time again.
car don't see snow i keep it under shed and previous owner garage kept it
the problem i have is i have to do everything by hand i don't have a machine polisher or buffer
someone suggested it could be oxidation and that i should use megs ultimate compound
i will be going at it this weekend anyone suggest a good sealant to protect the paint when am done with the process. will be using meguiars wash and wax car soap+dish liquid mix to strip the old wax. then rinse then wash again, using car wash soap only then clay,polish,wax and finally i guess sealant
i posted 2 new before pics for reference
Wet it down, wash it with your car soap.
Use your clay bar and lube on the car.
You might need to wash again if you have any clay residue left on the car (happens sometimes)
Use an Orbital Paint Correction Buffer (Flex, etc) with a medium polish and medium pad to polish the car. (Be careful of your pin striping...)
Sealants always go on before wax, they are meant to "bond" to the paint. After the Sealent has cured, you may put wax on the car.
Meguairs products are decent if you are limited to buying only what is on the shelf on stores.
Take a look at Optimum products if you want some really amazing stuff.
What gives paint the "pop" is the polishing step.
With those photos, I can't really determine any faded paint. The hood shot has a lot of gloss.
You can use dish soap to strip wax, but it's not something you would do on a regular basis. Since you don't have a machine polisher, you might try this new polisher that attaches to a drill. http://www.meguiarsonline.com/forums...read.php?56799
You asked a lot of questions before about doing someone else's car. Advice was given, and you still didn't clay the car. So I would suggest that you read up on some basics first. http://www.meguiarsonline.com/forums...guiar-s-Online
caudlek
Automotive Care & Detailing
07-22-07 06:01 AM
