cleaning tires and alloy rims
Proper Wheel Care
Modern wheels can enhance your car’s appearance and performance but they also present a substantial cleaning challenge. Heated dust particles from brake pads constantly bombard the wheel and bake into the finish. If left on the wheel, a phenomenon known as “galvanic corrosion” sets in which will eventually destroy the wheel’s appearance.
Unfortunately, car wash soaps and household cleaners are not strong enough to break the bond between brake dust and the wheel. To properly clean wheels, the car care industry has developed two groups of wheel cleaners:
1. The first group are acid-based cleaners. These are widely used by detailers, car dealers and car washes desiring to clean wheels in the shortest possible time or with the least amount of effort. Acid-based cleaners are typically a 2-3% solution of oxylic, phosphoric and/or hydrochloric acid. Most spray-on/hose-off wheel cleaners fall into this group. While these cleaners pack the greatest cleaning punch they can etch the surface if allowed to dry on the wheel. Care should also be taken not to use acid cleaners on wheels with pitted or chipped surfaces. The acid will migrate into any fissures and accentuate flaking and peeling of surface coatings.
2. The second group of cleaners are commonly called non-acid or acid-free wheel cleaners. These are mild solutions of an alkaline solvent, usually ethylene glycol, with a wetting agent. These solutions creep under the dirt and brake dust, loosening and lifting surface grime. Non-acid cleaners usually require some surface agitation (brush or sponge) but are safer to the wheel’s finish. P21S Wheel Cleaners (from Germany), Amazing Roll Off,and our Eimann Fabrik Hi-Intensity Cleaner are all 100% acid-free wheel cleaners. They range in strength from mild (P21S), to moderate (High Intensity Cleaner), to professional strength (Amazing Roll Off).
Once you’ve selected the proper wheel cleaner, here are some tips to make cleaning easier:
1. Clean the wheels first before washing the rest of the car. This prevents you from splattering cleaners, dirt and brake dust on already cleaned panels.
2. Do not clean wheels that are still hot from driving.
3. Clean one wheel at a time following the instructions on the cleaner. For extra tough grime and brake dust, agitate the surface with a soft, scrub brush. Do not allow any wheel cleaner to dry on the wheel.
4. Wax painted and clearcoated wheels for added surface protection and to facilitate future cleaning. Eimann Fabrik Clear Pearl II Instant Detail Spray is excellent for this application. Simply spray it on a dry wheel and wipe with a soft towel. Or, apply a coat of Wheel Wax.
Don't forget a wheel brush in clean them properly like these two from ProperAutoCare.com. The E-Z Detail Brush and / or our World Famous Eimann Fabrik Wheel Woolies.
http://www.properautocare.com/eifawhwo.html
http://www.properautocare.com/ezdetailbrush.html
http://www.properautocare.com/p2wheelclean.html
http://www.properautocare.com/ro-32.html
http://www.properautocare.com/hi-c32.html
http://www.properautocare.com/wheelwax.html
________________________________________________________________
Proper Tire Care
Always remember to clean your tires when you wash the car. To clean your tires, use a cleaner formulated for tires. Car wash shampoos are too gentle to penetrate into the tire’s pores and lift out imbedded grime. Products like BLACKFIRE Gel Wheel & Tire Cleaner, Amazing Roll Off, and Eimann Fabrik Hi-Intensity Cleaner are excellent as they deep-clean without bleach. Bleaches are used in many tire cleaners to whiten whitewalls but they turn tires a dull gray and can stain alloy wheels.
After you’ve cleaned your tires you may desire to apply a dressing to accent their appearance. The car care industry provides you with two groups of dressings to choose from:
1. The oldest and most familiar group are the oil-based silicone emulsions. These dressings produce the highest gloss but stay slightly “greasy” on the tire’s surface. Eimann Fabrik Ultra Black Tire Dressing falls into this category. It has the highest gloss of any product we offer.
2. A newer group of dressings are water-based. These dressings produce a more satin or natural finish but dry completely to minimize dust attraction. Many water-based dressings also contain a UV screen which aids the tire’s own UV absorbers. 303 Aerospace Protectant , Lexol Vinylex, Optimum Tire Shine, Autoglym Instant Tyre Dressing, and Meguiars Hyper Dressing are some of the water-based dressings to use.
http://www.properautocare.com/blgelwhticl.html
http://www.properautocare.com/eifaulbltidr.html
http://www.properautocare.com/ts2007p.html
http://www.properautocare.com/mehydr.html
Proper Tire Care
Former Sponsor
The Ultimate Wheel Cleaner - Sonax Full Effect Wheel Cleaner
Here is a complete wheel/tire kit
Uber Wheel/Tire Kit
Uber Wheel/Tire Kit
Here are some more for your viewing:
BLACKFIRE Quick & Easy Wheel & Tire Kit, Wheel Wax Tire & Wheel Care Bucket and this kit has everything you need to start taking care of your ride, P21S Car Care Kit.
http://classic-motoring.stores.yahoo...221detkit.html
http://classic-motoring.stores.yahoo.net/blwhtikit.html
http://classic-motoring.stores.yahoo...axtiwhcab.html
