smells like gas - please help
My garage smells like gas so i popped the hood and found out it was coming from there.
What seems to be the problem???
I can't visually see anything leaking but i can definately smell gas under the hood.
And it's July 4th today and i don't want some firecracker blowing up my car today...
What could be the problem and how can i fix this?
Keep in mind gas leaks if minor are hard to see because gasoline evaporates quicker than water. But if the leak was substancial then you better not drive the car.
Open the garage, then close after a few mins to let the fumes out. Then wait an hour and see if you are still smelling gas from the same source.
If you are still concerned and want to avoid the risk then have it towed to your local dealer or have a mechanic take a second look.
I took my 06 IS 350 to the dealership for the cam gear recall. Afterwards everything was fine however I started noticing fuel vapor like smells coming from the hood area. So, I took it in again and they diagnosed that my main fuel tube line (part# 7725153050) was the culprit. My SA said the part would take one month to arrive because it is on back-order. As soon as the part came in it was a simple remove and install. I haven't noticed the vapors at all since.
Bad news...Lexus tech guy said my fuel line was leaking very bad and could have caught on fire.
He will have to replace 2 parts...one cost $130 and other cost $50...and it will take 4 hours labor cost.
They estimated $600 total damage.
They going to replace one line that goes from engine area to the back area near fuel tank...and going to replace other line that runs to the intake area.
Some guy on here said its a simple remove and install...but Lexus tech guy saying 4 hours labor.
Anyways another $600 gone down the tank!!!
scboat400 (09-01-21)
It is a simple remove and install. Just buy the fuel line and install yourself. Im sure there is a youtube out there to do it.
a good chunk of that is all labor cost, which usually is about $90-120/hr for labor charge. But if you are already there and have no time to do it, then just get it done and be safe.
1st time i've heard of a fuel line leak issue for the IS
