quick camber question
hey guys, i just wanted to double check something. im purchasing a megan camber kit to fit some aggressive wheels i just bought. im assuming ill need to run some additional neg camber. just wanted to confirm the part number im ordering is MRS-LX-0311. the last thing i want to do is order something and then get hit with a restocking fee. heres a link. thanks in advance
http://www.meganracing.com/products/...d=886&catid=25
How aggressive are we talking? I ended up changing everything except the LCA in the rear, heres what i purchased, its best to purchase all, then to find out the hard way which I did, I included the link you provided to list you need.
http://www.meganracing.com/product_d...d=907&catid=91
http://www.meganracing.com/product_d...d=908&catid=91
http://www.meganracing.com/product_d...d=909&catid=91
Only reason I am saying this is because I had to replace all those parts minus the traction rod, the previous owner cut and shortened my factoru arm by rewelding them, so when i bought one part, the actual megan part was didn't work because it was too long., I would look into FIGS arm they cost almost the same as megans and better quality, I wish i would've known before i bought megans,
Well my wheel specs are 9.5 +25 for the front and 10.5 22 for the rear. Im going with 225 35 and 245 35 as far as tires go. From what I've read some ppl said ill b ok in the front (of course fender mods). As for the rears by adding the megan camber kit I should be okay that way I don't rub. Again guys any opinions are more than welcome
Rub is cancer, your going to rub unless you run a custom fender, I know someone on the forum converted his whole front into the OEM isf conversion with the fender as well to eliminate the fronts from rubbing, Im running 18x10.5 +3 in the fronts and it rubs all day i gotten use to it by now,
jnguyen87
12
05-30-11 03:06 PM
