Installing MY2011 headlight
I've purchased the MY2011 headlight from Sewell earlier and planning to install them on my 09 isf soon.
I already knew about the AFS light flashing problem on the dashboard and I'm planning to just put a black tape on it and cover it.
However, will I still have the auto-leveling and auto left and right adjust functions after I install them?
Are the headlights direct plug-in or do I need some modifications?
I'm confused right now...
Please help!
Please help!
Please help!
Please help!
If from Sewell, they will plug and play - Sewell re-pins them for you.
Digger08
If you ordered the loaded version then they are pretty much plug and play. If you got the stripped version then you will have to transfer over your ballast and one turn signal light. PM me if you need some help. I've done the stripped version 4 times already. Also, hopefully you got the new brackets too.
You don't have to order the new brackets, but it will make the installation easier. If you use your old brackets, you will have to modify them to fit correctly. There's no need to cut the bumper.
You can order them from Sewell (http://sewellparts.com/). They are a CL vendor. Just make sure to create an account in order to get your CL discount.
5211553042
SUPPORT, FRONT BUMPER SIDE RIGHT / PASSENGER SIDE 01 In Stock $84.70 $84.70 $62.12
5211653042
SUPPORT, FRONT BUMPER SIDE LEFT / DRIVER SIDE 01 In Stock $84.70 $84.70 $62.12
5211553042
5211653042
This person wrote up a pretty detailed DIY, but you're looking at step 17.
As an additional FYI, you'll also want the correct flasher unit.
