Traction control
Old 08-03-13, 06:52 AM
Jimt9
Jimt9's Avatar
Default Traction control
I read something on the net that said on The F sport I can turn off the traction control? Is this true?
I bought and IS 250 AWD F sport, will my car have this feature?
Old 08-03-13, 09:10 PM
alopez
alopez's Avatar
Yeap! Just press 5 sec the Trac Control and you will see on your dash the yellow light turn on.
Old 08-03-13, 09:21 PM
Jimt9
Jimt9's Avatar
hey thanks for the tip
Old 08-04-13, 07:42 AM
alopez
alopez's Avatar
Old 08-04-13, 08:16 AM
AndyL
AndyL's Avatar
Does it also work for the regular IS? I don't have the car yet..
Old 08-04-13, 10:25 AM
alopez
alopez's Avatar
I'm sure yes... You only can turn off the traction control only when the car is in (P) or (N)
Old 08-04-13, 02:00 PM
AndyL
AndyL's Avatar
Thanks alopez. But once disengaged, will the traction control restore after the car has attained a certain speed?
Old 08-04-13, 04:47 PM
RA040224
RA040224's Avatar
It has two modes, one quick press turns off the traction control (TRC OFF), and this will turn back on when you increase the speed (for situations where you're stuck in mud or snow). If you press and hold for more than three seconds, you also turn off the stability control (TRC OFF and VSC indicator will be lit). This will not turn back on when speed increases. Note also that the pre-crash safe system will be disabled...
Yeah, I've been browsing the user manual tonight
Old 08-04-13, 05:23 PM
AndyL
AndyL's Avatar
Thanks for the info. The first mode - traction control resumes after a certain speed exists in 2IS. The 2nd mode - with the traction control button pushed and disabled entirely - it is not available in 2006 2IS but is available in the subsequent years (07-13) but in any case, the traction control button is a bit hidden by the steering wheel.
Old 09-28-13, 11:37 PM
dbs600
dbs600's Avatar
What exactly does the SNOW button do? What does it change?
Old 09-28-13, 11:56 PM
jhs82
jhs82's Avatar
It lowers the engine output in the lowest gears to avoid wheelspin and slip when starting from a stand still.
Old 09-29-13, 12:11 AM
dbs600
dbs600's Avatar
Cool; thanks.
Old 10-01-13, 07:43 PM
dbs600
dbs600's Avatar
Does the SNOW button only help when at a standstill or does it tweak something else as well when moving in snow conditions?
Old 10-01-13, 08:09 PM
dseag2
dseag2's Avatar
Also, I think you will have to disable traction control each time you drive the car. It comes back on automatically.
Old 10-02-13, 06:15 AM
jhs82
jhs82's Avatar
No, only when starting from standstill. It disengages when you achieve a certain speed. Don't remember how fast. It's all described in your user manual.
Quick Reply: Traction control
