right passenger mirror doesnot work
Old 04-27-13, 10:43 AM
gegaaaa
gegaaaa's Avatar
Default right passenger mirror doesnot work
guys i am new here. i have a little problem regarding passenger mirror.
it doesnot work, no reaction no sound. today i took little motor from the mirror i thougt that motor was damaged. Than i put thit motor my friends rx400h and it worked perfectly. Any ideas ?
I think it may be due to fuse, but i dont know exact fuse to replace.
Old 04-27-13, 02:00 PM
katzjamr
katzjamr's Avatar
you have a switch for the passenger mirror and the driver mirror, it has three positions left for the driver, middle is neutral and right for the passenger. is this switch toggeled to the right so that the mirror can be adjusted?
Old 04-27-13, 07:53 PM
HtownBlue
HtownBlue's Avatar
Push your switch to the far right then report back.
Old 04-28-13, 12:49 AM
gegaaaa
gegaaaa's Avatar
Guys i switched to the right but nothing again no reaction the motor works 100 pct. i have checked it
Old 04-28-13, 02:17 AM
gegaaaa
gegaaaa's Avatar
guys i ve checked the fuses and pwr oulet n.2 fuse is damaged. for what is this fuse i dont understand. And one thing i noticed is that passenger mirror is somehow yellow colour. why?
Old 04-28-13, 05:01 PM
HtownBlue
HtownBlue's Avatar
Replace your fuses that are bad. The yellowing is due to the mirror itself getting old. Several threads on that.
Old 04-29-13, 12:45 AM
gegaaaa
gegaaaa's Avatar
Guys i solved the problem. I removed the door panel and find out that white plug of the mirror was not connected to mirror block. So i connected and everything is ok. thank you all
nateses300
06-10-14 02:56 PM
DrDan
RX - 1st Gen (1999-2003)
04-23-12 02:24 PM
HKSC430
06-15-10 11:45 AM
kRonX
12-21-07 06:20 PM
martini3
08-27-07 10:55 AM
Quick Reply: right passenger mirror doesnot work
