The Mother of all LS430 Fuel Threads: Regular, Midgrade, or Premium? (merged)
ya, tried searching, but mostly debates, no majority conclusions. Mostly accept GS is not a good gas car, and premium grade gas is a waste.
My other question I am trying to research is how the LS430 gets such better mileage than the GS? I also notice that my car won't 'go' in low gears, unless my foot is on the gas, whereas the LS cruises to a stop, mine is almost fighting to go to the next gear, I guess cause the GS takes advantage of higher RPM to be such a fast car.
.Are you comparing your GS400 to your parent's LS430 or some other LS? If you're comparing the GS400 to LS430 they are two different engine versions 1uz vs 3uz.
Interesting that GS430 mileage is 18/23 vs LS430 18/25. I'd suspect gearing in the GS might be taller/more aggressive impacting the highway rating.
sorry, 1uz vs 3uz, uz?
Comparing what I know, my 98 GS4 vs his '01 LS430, sick 1 tank of gas to Canada.
And by premium, do you mean 89, or 91+?
Premium is 91+ (depends on your geographic area), not mid grade 89
i have a 90 ls400 and i NEVER use anything less then 93octane yeah i guess it sucks using premium but i knew that before i bought the car so i dont even notice really.
JUST USE 93 u can afford it if u have a 03 ls430 u can cough up the extra 3$ per fillup
I dont mean to crack on daryll40, because he was just asking a question.
http://www.theaa.com/allaboutcars/fuel/
That works out at $8 a gallon. To fill up an LS430 that would be almost $200.
Here's a direct comparison:-
http://www.theaa.com/allaboutcars/fuel/motfue001.html
UK pays 90.3 pence per liter, US is 28 pence per liter.
LS430 is $120,000 equivalent there too.
How do you feel now?
91- 28 MPG
89- 24 MPG
87- 21 MPG
This was done on several trips over the same stretch of 5 FWY running the length of CA. The price is relative to what I got in perfomance and mileage. On that 2K trip, the difference adds up. Stopping to get gas at an isolated station where the prices are jacked, it is nice to just keep on driving.
imho, i wouldn't even consider 89. if you do the math, between 89 and 91, maybe you end up paying about 100 to 150 bucks more each year... i think that's insignificant enough, considering that you paid like 60k for the car
Why? Well, in the unlikely event that the knock sensor fails, I don't want detonation occuring in my engine. Sure, it will retard timing when it is working properly, but what if it doesn't? The cost of the higher grade gasoline is not all that more expensive, and I like to think I am buying a little cheap insurance with each fillup.
Plus, premium gasoline has more detergents, which should help keep the engine cleaner.
On a less serious note, removing the hood and rear doors would probably be detrimental to the fuel economy. It would cause more drag. I suggest replacing the hood with one made of carbon fiber. Then stripping out the passenger seat and the rear seat. Furthermore, I believe that you may want to consider tossing out the door mats, removing the interior panels, stripping out the insulation, and ripping out all of the carpeting. Replacing the driver seat with a race seat might also cut a few pounds.
